Prestolite ot Motorcraft Ignition - JeepForum.com
post #1 of 2 Old 08-03-2002, 11:44 AM Thread Starter
mrjoshuaw
1977 CJ7
Also posted this in the CJ forum, just covering all bases. Thanks for any help.
Ok, Here is the deal. Did not have any spark coming off of the coil. Found out that the ECM (electronic control module) was bad, replaced it and the engine ran very rough. Replaced the coil and the engine smoothed out. After running for about 3 months the engine started to run rough again and then low and behold it failed to start. Once again no spark coming off of the coil. Main question is would it be worth it to change from the prestolite to the motorcraft ignition system? And if so how much trouble would this be? Maybe Jeep only made this style for 2 years for a reason? If any could let me know that would be great. The price difference is also a factor since the prestolite is more expensive to keep replacing parts. Or if anyone has an idea as to what is causing the ECM to go bad that would help also.
"In the End Everything is a Gag...." Charlie Chaplin
mrjoshuaw is offline
post #2 of 2 Old 08-08-2002, 10:53 AM
4wheeler4CJ
4wheeler4CJ's Avatar
You can switch to Motorcraft or even go HEI Conversion, which is much easier and better.
Prestolite is/can be pretty crappy sometimes, and very troublesome, in my past experiences.
4wheeler4CJ is offline
prestolite upgrade blackhawk099 Engines & Drivetrain 2 07-19-2009 04:58 PM
Motorcraft carb help cibholder03 Engines & Drivetrain 33 06-08-2009 09:16 AM
Prestolite control module question scottymac62 Engines & Drivetrain 1 11-16-2008 12:32 AM
motorcraft vs weber scotng Engines & Drivetrain 0 02-18-2004 09:18 AM
Motorcraft/Autolite Carb on 258 xxxflhrci Engines & Drivetrain 1 12-18-2003 08:28 PM
