pressure in valve cover - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > pressure in valve cover
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6
Unread 04-09-2005, 08:47 AM   #1
88Blackwrangler
i have a 4.2 on my 88. It seems like there is a ton of pressure in the valve cover. When i take the oil cap off there is lots of smoke or fumes coming out and alot of oil coming in the air cleaner.
I have also noticed it seems like if i put oil in it takes a while to go to the crankcase. I dont think there is blow by because the plugs look clean and the motor still have decent power when the air filter isnt oil soaked.
Could there be enough sludge in there that the oiling holes are clogged that under running conditions the oil if forced into the valve cover but it doesnt return and instead just goes out the pcv into the air cleaner?
just want to check all options before an engine switch.
Thanks
88Blackwrangler is offline   Reply With Quote
Unread 04-09-2005, 01:45 PM   #2
COJAM
You have a clog. Try replacing the PCV valve and breather. Also, you may want to take off the valve cover and give it a good cleaning.
GBD
COJAM is offline   Reply With Quote
Unread 04-10-2005, 01:53 AM   #3
Scrambler82
Scrambler82's Avatar
1982 CJ8
Ditto and if there is any kind of rubber tubing between the PCV and the intake, check it for two things:
1) Blockage, sometimes the insides of the hoses come apart and clog things up.
2) Softness in the rubber, if the hose is worn out the hose may collapse when it is suppose to be work'n.
Later,
Scrambler82
Do it right the first time !
Scrambler82 is offline   Reply With Quote
