Preparations for an aussie locker? - JeepForum.com
post #1 of 7 Old 10-07-2007, 10:41 AM Thread Starter
Edward777
Ok guys soon im going to install my locker is there anything else i should replace while im in there my jeep has about 75,000 miles on it.
8.8 swap, Aussie FL, 2.25 BB Monotube, JKS quick Disconnects, 15x8 MT classics 32x11.50 SSR
Edward777 is offline
post #2 of 7 Old 10-07-2007, 11:41 AM
Ryanpowell167
There is really nothing you HAVE to replace. Unless you get crazy pullin out the axles, then the seals should be fine. Everyonce in a while you have to replace one reguardless anyways. Just buy a tube of silicone and be gentle when pulling you shafts...
Black 1992 wrangler, 40" creepy crawlers, d60/14b 350tbi/700r4/np205, spring over on 4" springs.
2011 Ford F-150 Raptor, whipple supercharged...
Ryanpowell167 is offline
post #3 of 7 Old 10-24-2007, 11:41 AM
Jakemd98
Choosy moms choose jeep.
Jakemd98's Avatar
WELL! You will need to replace the side bearings on your carrier, along with your driver side axle u-joint, and driver side hub assembly.
Probably should get a shop to do the bearing swap, it should run you about $130 plus how ever much your bearings run. And i would recommend replacing both axle u-joints.
ALL i can say is tomorrow will be a lot of fun!!!!!!
Jake Davis
97 Jeep Wrangler
4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery.
1998 GMC Yukon
Jakemd98 is offline
post #4 of 7 Old 10-24-2007, 12:52 PM
jeepster93
jeepster93's Avatar
Now would be a good time to install a armor diff cover.
You don't need to replace the carrier bearings with an Aussie locker.
jeepster93 is offline
post #5 of 7 Old 10-24-2007, 02:30 PM
Northridge4x4
Vendor
Northridge4x4's Avatar
You dont need to anyof this just install it and go wheeling.
David
866-601-5340
Your Trail Starts Here
FREE SHIPPING ON ALL ORDERS OVER $70
Northridge4x4 is offline
post #6 of 7 Old 10-24-2007, 05:47 PM
Jakemd98
Jakemd98's Avatar
David
LOL... actually he does, or should i say he did. I was just messing with him, because once we tore it apart we found that the bearings, driver side u-joint and hub were all shot.
But now that i think about it i should have let y'all know that i was just messing with him. if you read this disregard my previous statement as tech (unless all that stuff is actually bad on your rig) because it is not needed to do an aussie install.
Jake Davis
97 Jeep Wrangler
1998 GMC Yukon
Jakemd98 is offline
post #7 of 7 Old 10-24-2007, 06:46 PM
Northridge4x4
Vendor
oh ok understand.
David
866-601-5340
How to install a ‘lunchbox’ locker (ex locker, aussie locker, etc) in your D30 axle. CanukYJ Fabrication Shop 107 12-04-2011 07:14 PM
aussie locker? redneckup General Jeep & Off-Road Equipment 20 03-28-2009 06:53 PM
Aussie locker elkfan2 Engines & Drivetrain 1 03-17-2009 10:49 AM
Aussie locker outlawjosywales Engines & Drivetrain 2 02-01-2009 05:33 PM
Aussie locker Diehard Tires & Wheels 6 12-07-2005 10:07 PM
