Power steering fluid hot and makes noise - JeepForum.com
post #1 of 2 Old 03-24-2007, 09:37 PM Thread Starter
RenoHal28
I have replaced my power steering pump with a remanufactured one and the steering seems to be doing ok. While bleeding the power steering, everything seemed good and all the bubbles appear to be gone. I seem to have good circulation (after cleaning out the female connector for the high pressure fitting.. this is what made my last psp blow up). The only problem I'm noticing is that it gets really hot. The pump itself doesn't smoke, but when I open the cap, the fluid is smoking a little and the pump and hoses are too hot to touch. Also, it is making a noise like it's dry, but the fluid level is exactly where it's suppose to be. Could the belt tension cause this? I have about 1/8" give on the belt. Maybe I should loosen it a little to about 1/4"? I just gotta get this jeep going. Any help would be greatly appreciated.
'90 Jeep Cherokee Sport 2WD 6cyl 4.0L
2WD 6cyl 4.0
RenoHal28 is offline
post #2 of 2 Old 03-25-2007, 08:49 AM
Vestjam
I'm not sure why the fluid is getting that hot, but only 1/8" of play seems a bit tight to me.
Try your thread up in the XJ section. There are some smart people up there with lots of experience.
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
CB makes popping noise & turns off KilgoreTrout Audio, CB & Ham Radios, GPS, & Electrical 8 10-15-2009 01:08 PM
front end makes clunk noise the dawg Engines & Drivetrain 2 08-06-2006 01:47 PM
Rear-view mirror makes too much noise seel2000 Audio, CB & Ham Radios, GPS, & Electrical 3 02-16-2006 10:48 AM
CD player makes noise when accessing US1 Audio, CB & Ham Radios, GPS, & Electrical 0 02-07-2005 10:29 PM
Power Steering Fluid JeepGal Engines & Drivetrain 2 10-19-2002 06:05 PM
