Quantcast Power loss - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Power loss
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 09-04-2003, 11:55 AM   #1
SpikeSpeigel
Power loss
Ok.... After about 3000rpm I have about 50% power(if that). I just changed air filter. I need to change PCV valve. I was told sludge in the valve cover could cause this also. I took the valve cover off and it looked ok. Could I add some marvel mystery oil to my oil? Will that help it clean up? Are either the sludge or the PCV valve causing my problem? Could it be that peices from my catalytic converter are clogging my exhaust? Please list some things I could check. Thanks
[B]'99 XJ 4x4[/B]
[SIZE=1]RE 5.5" front coils, TNT Customs Y-link radius arm kit, S-10 rear leaves, RE .75" shackles, ORO u-turn steering, SYE/CV driveshaft, YJ brake lines, 33" BFG MT's, K&N drop-in, Flowmaster 40 series, Tow hooks, Trimmed fenders, M.O.R.E. motor mounts, TNT Customs frame stiffeners, RE HD trackbar/mount, Autometer Trans temp gauge w/ pillar pod
[/SIZE]
"Sticking feathers up your butt does not make you a chicken!!"
[CENTER]-Tyler Durden[/CENTER]
SpikeSpeigel is offline   Reply With Quote
Old 09-04-2003, 02:54 PM   #2
awachwhiteboy
1975 CJ5
I wouldnt add marvel to your oil, only to do a comp checkwith it, which it sounds like it would be a good idea for you to do. How many miles are on it? what engine? The PCV could have sludge in them and that does cause engines to run wierd. Pieces from the cat clogging your exhaust? not very likely. When is the last time you did a tune up? Plugs. plug wires? cap and rotor?
Sacramento Jeepers Group #1
awachwhiteboy is offline   Reply With Quote
Old 09-04-2003, 04:01 PM   #3
SpikeSpeigel
I did the check engine light trick and it said O2 sensor was reading lean fuel mixture. I bought a new o2 so we'll see if that helps.
[B]'99 XJ 4x4[/B]
[/SIZE]
Old 09-06-2003, 11:16 AM   #4
SpikeSpeigel
Well I took the O2 sensor back after getting a new flowmaster exhaust form my friends shop. Turns out the cat had broken and turned sideways blocking the airflow. The new exhaust cost $53... 60cents more than the O2 sensor
[B]'99 XJ 4x4[/B]
[/SIZE]
Glock Forum
