Popping noise in front end. - JeepForum.com
post #1 of 2 Old 11-01-2012, 04:37 PM Thread Starter
jeepsrtoys
1997 XJ Cherokee
I have a 97 cherokee. The front track bar has gone bad. The ball joint in it has worn and just started popping. It looks like an easy fix. Just not sure if i should undertake this in my garage. The part will cost me about $80, just need some advice if i should do it, or take it some where.
jeepsrtoys is offline
post #2 of 2 Old 11-01-2012, 09:54 PM
cbush314
The part that you are talking about is called a "heim-joint". You can get it a little cheaper that 80 bucks. But I replaced mine in August because it too popped. But now it still pops even though everything is tight. So I would say to you unless the handling is bad, don't replace it.
Sent from my DROID X2 using JeepForum
cbush314 is offline
