Pointers on rear main install - JeepForum.com
post #1 of 3 Old 03-19-2007, 01:21 AM Thread Starter
etnies88
Tonight i removed the rear main which was a pain in the *** getting it out of the block.
Im going to the dealer for parts tomorrow, Anyone have some good pointers to suggest. I have been looking at a DIY on a website somthing about putting soap on the seal and oil and some sealeant?
Main reason i replaced was the oil leak it was really getting worse, plus i dont have to worry about running low on oil and screwing everything up
90 XJ 4Dr Limited *Current*
90 XJ 2DR Standard *SOLD*
90 XJ 4DR Laredo *SOLD*
97 Integra GSR *JRSC* 4cy fun.
etnies88 is offline
post #2 of 3 Old 03-19-2007, 07:48 PM
jeep_on
Should be a two part seal. If it is, its easy to replace. Get a service manual at a parts store.
2006 Dodge RAM Laramie w/ 5.9L I6
2010 Volkswagen Jetta w/ TDI 2.0L I4
Waiting on a 2013 RHD JK Unlimited
Originally Posted by PM Thor View Post
Wait, you can't cross creeks up there? What the Hell is up with these Canadians?
jeep_on is offline
post #3 of 3 Old 03-27-2007, 10:45 AM
gomes512
1994 ZJ
Yeah that replacement was a real PITA when I first did it on my buddy's jeep. Buy like 2 or 3 of those seals cause they have a tendency to get scraped by the block if your not careful slipping 'em back in. Once they get scraped your back to square one (leaky seal).
Like you mentioned, the soap and oil will really really help you out. Also, you may want to consider using a "sneaky pete" oil seal remover/installer kit. They will help you out and its like $24 at sjdiscountools.
gomes512 is offline
main bearing install write up ? mark12010 Engines & Drivetrain 6 10-01-2008 06:08 AM
rear main on a tj hazmat Engines & Drivetrain 2 08-17-2007 11:27 PM
258 Rear Main mitchj01 Engines & Drivetrain 1 02-14-2004 07:46 AM
Rear Main Oil Seal compfreak2002 Engines & Drivetrain 5 06-28-2002 03:44 PM
