Please help w/ Tranny - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Please help w/ Tranny
Warn and Smittybilt Free Shipping OfferNew items recently added to Oconee Offroad15 x 8 Black D-Window Steel Wheels Set of 4
Unread 04-26-2006, 10:41 AM   #1
willysmb1
O.K.
1988 YJ 4.2L Peugot Tranny
My problem, or question rather. On the driver side of the tranny, there is two metal lines. One goes up to the Clutch master cylinder, the other comes out about 5 or 6 inches from the tranny and has a brass looking fitting that has a nipple on one end. Is there supposed to be a hose or line connected to this second line or not? It just looks like a open line. Might just be a dumb question. This thing marks its territory everywhere it parks, not sure from where yet, I do believe I have a bad seal in the tail shaft of the transfer case, but not sure about this line. Thanks for any help,
Michael
FLY NOW, WORK LATER!!!!!
1942 Willys MB stock work in progress
'88 YJ 4.2L 5spd; 4" ProComp Lift
15x8 ProLine Model 139's
33x12.5 Goodyear MTR's
willysmb1 is offline   Reply With Quote
Unread 04-26-2006, 10:57 AM   #2
Tshark299
1987 YJ Wrangler
Mine has that second line with the nipple to, also not connected to anything. I assumed it was for bleeding the air out of the system, but I've never had to mess with my clutch so far.
'87 YJ Laredo - 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
'95 XJ - Donated drive train to the YJ, Parting the rest out
'51 CJ-3A - Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline   Reply With Quote
Unread 04-26-2006, 11:12 AM   #3
75SV1
The second line is for bleeding the slave cylinder and the master cylinder. If your leaking from the slave cylinder, then its time to replace it.
Tom
75SV1 is offline   Reply With Quote
Unread 04-26-2006, 01:23 PM   #4
willysmb1
Thanks guys, wanted to make sure there wasn't supposed to be any thing connected to it. Thanks
Sonny
