Please help, 95 YJ wont start - Page 2 - JeepForum.com
post #16 of 45 Old 04-22-2014, 05:04 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Questions:
Does this engine turn over?
The fuel pump does not run. Did you check the fuse #5 in the fuse block?
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is online now
post #17 of 45 Old 04-22-2014, 05:44 PM Thread Starter
ayj4u2c
The engine does turn over. All fuses under the dash are good. Except there is no power to the one labeled ACC LPS. Which would be #10 on your diagram
ayj4u2c is offline
post #18 of 45 Old 04-22-2014, 06:13 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Fuse box list...forgot to post it!
Let me get back to you in a minute or three. Do you have a multimeter?
post #19 of 45 Old 04-22-2014, 06:20 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
If the starter does not make a sound then let us think about the starter circuit.
I'm freaking losing it. You need to check fuse #4 in the PDC under the hood.
FORGOT THIS!!!!
If that fuse is NG you get NADA from the ignition switch. Pull the fuse and check it with a multimeter unless it is obvious that it is blown.
post #20 of 45 Old 04-22-2014, 06:37 PM Thread Starter
ayj4u2c
Fuse #4 in PDC just checked and it is good!
ayj4u2c is offline
post #21 of 45 Old 04-22-2014, 06:44 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Here is some more information. It is part of a thing I have been working on. I gathered much of this from a FSM and then tried to turn it into English.....sort of.
IGNITION SWITCH
Circuit A1 from fuse 4 in the POWER DISTRIBUTION C ENTER (PDC) supplies battery voltage to the ignition switch. Depending upon position, the ignition switch powers circuits A21, A22, A31, & A41.
START POSITION
In the START position, the ignition switch connects circuit A1 to A41.
Circuit A41 connects to the coil side of the starter motor relay.
The other (coil) side of this relay is a ground supplied by the NSS switch in the automatic transmission. For a standard shift, a ground wire on the dipstick tube hold down bolt supplies that needed ground.
One the other side of this relay is the power from the 40 AMP fuse in the PDC that when A1 connects to A41 the relay closes, IF it has ground. Then battery voltage goes to the starter motor solenoid. That is the power for your starter motor solenoid. The start itself should always have power from the battery + battery cable.
START OR RUN POSITION
In the Start or RUN position the ignitions switch also connects circuit A1 with circuit A21.
The A21 circuit connects to fuses 5 & 9 in the fuse block.
Fuse 9 powers circuit G5.
Fuse 5 powers circuit G50 which supplies power to the coil side of the Automatic Shut Down (ASD) relay.
Circuit G5 powers the buzzer module.
Circuit G5 also splices to power the daytime running lamps module if it is a Canadian model, the AC compressor clutch relay, the heated rear window relay, and the gauges and indicator lamps in the instrument cluster.
post #22 of 45 Old 04-22-2014, 06:49 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
If I didn't mention this already. Turn the ignition switch to the ON position. Pull the starter relay in the PDC. Jump slots 30 to slot 87 with a hunk of wire. Does it start?
post #23 of 45 Old 04-22-2014, 06:53 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
I edited post #19
post #24 of 45 Old 04-22-2014, 06:56 PM Thread Starter
ayj4u2c
Jumping the wire from 30 to 87 does not start it. I have a new solenoid for the starter coming tomorrow because NAPA told me it was bad when they tested it. I'm nt so much worried about it not starting as much as I am about why my fuel pump no longer has power going to it.
ayj4u2c is offline
post #25 of 45 Old 04-22-2014, 06:58 PM Thread Starter
ayj4u2c
And Thank you so much for all your help, your knowledge is great and are a good teacher. I've learned a lot already.
ayj4u2c is offline
post #26 of 45 Old 04-22-2014, 07:10 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
One more thing. Check fuse #5 in the fuse box. It is for the ASD relay. If the ASD relay gets no power neither does the fuel pump relay.
post #27 of 45 Old 04-22-2014, 07:22 PM Thread Starter
ayj4u2c
Fuse #5 checks out ok
ayj4u2c is offline
post #28 of 45 Old 04-22-2014, 07:34 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Maybe it is the starter solenoid. You have jumped power from the starter motor lug to the starter solenoid and got no response. If there is good voltage t the starter motor lug then the solenoid is the most likely culprit.
Stick in in and let me know how you make out.
post #29 of 45 Old 04-22-2014, 07:46 PM Thread Starter
ayj4u2c
Will do.
ayj4u2c is offline
post #30 of 45 Old 04-24-2014, 12:25 PM Thread Starter
ayj4u2c
So I haven't gotten the solenoid yet, but I've got to thinking about what I did to the jeep in between the time it started and then didn't start. Is it possible I fried my PCM by doing a bunch of welding on the jeep without disconnecting the battery first?
ayj4u2c is offline
