please help!!! - JeepForum.com
post #1 of 7 Old 05-08-2002, 04:22 AM Thread Starter
twobryans
please help!!!
can anyone please help me. a friend has a 1985 wagoneer with a 5.9 liter v8 the truck has no spark and of course, he had someone else try to fix it and they have replaced the ign module, distributor, coil, battery and starter solenoid. it was brought to me with the distributor out and i have put it back in and checked and have no spark out of the coil. the distributor does turn. i do have current to the coil and to the ign module, but no spark at all. can anyone give me any direction at all?? thanks in advance for any and all help.
twobryans is offline
post #2 of 7 Old 05-08-2002, 05:04 PM
mozz
mozz's Avatar
Did you try the pickup coil in the distrubtor?
'78 CJ7
360 cid W/390 heads
edelbrock intake W/matched performer plus cam,springs and timing chain
Hedman Fenderwell headers
4WD Fiberglass Body
4" lift W/ 35" BF Goodrich AT
Pioneer CD player W/ Pioneer 200 watt amp 10 in. sub speaker box Shoved behind rear seat for now (Till I can make a permanent box)
mozz is offline
post #3 of 7 Old 05-08-2002, 05:13 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Sounds like the ignition stator or the wires going to it. This is located in the distributor and is also called the pickup coil. I have the same engine and am real familiar with the ignition system.
Steve
OldJeepguy is offline
post #4 of 7 Old 05-08-2002, 05:13 PM Thread Starter
twobryans
i personally didn't replace the pickup coil, but the guy before me put a new pickup coil in the original distributor and then they replaced the whole distributor with a reman. unit that came with a new pickup coil. i really don't want to start buying more new parts as all of it is already new(but could certainly have a bad new part).if i could only find a wiring diagram for the ignition system, i think i can figure it out as soon as i know what each wire does. i appreciate the help so far and would absolutely appreciate any other help that anyone may be willing to offer. thanks.
post #5 of 7 Old 05-08-2002, 05:23 PM
mozz
mozz's Avatar
I could email you a diagram if need so
'78 CJ7
360 cid W/390 heads
4WD Fiberglass Body
mozz is offline
post #6 of 7 Old 05-08-2002, 06:08 PM Thread Starter
twobryans
mozz,
i would say that would make you "THE MAN" in my book. i would greatly appreciate that and anything else you could send that you might think could be helpful. might you also have a diagnostic "tree" chart for the ignition system?thanks very much!
post #7 of 7 Old 05-09-2002, 02:15 PM
mozz
mozz's Avatar
let me know if it helped
'78 CJ7
360 cid W/390 heads
4WD Fiberglass Body
mozz is offline
