Pistons - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Pistons
Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!
Unread 10-23-2001, 08:52 AM   #1
Mackddy6
Pistons
I have a couple of questions...first off: Is the 304 block the same as a 360? I know on a 360, the stroke is the same as the 304, but the bore is different. Do I have the same block? Also...does anyone know where I can get pistons...only pistons...for a 360? or if I can bore out the cylinders to fit a different type of piston...what type can I use? I appreciate any help. Thanks..
Josh
Josh
'75 CJ-5 360, headers, 4 barrel, full custom cage, custom body mounts. Soon to have:FSJ D44s, 36 inch Goodyear MT/Rs, custom spring mounts, SOA, 4" lift springs, 2 inch body lift
It's better to beg forgiveness than to ask permission
Mackddy6 is offline   Reply With Quote
