Pinion seal. Brakes - JeepForum.com
post #1 of 4 Old 04-30-2013, 07:25 PM Thread Starter
rug_15
Pinion seal. Brakes
So yeah this is prolly already on here. But I'm using my phone and it's hard. I have a 2000 4.0 Tj. Stock axels. Just replaced rear pinion seal. And it's still leaking! Someone said something about a crush sleeve? Is this needed? All the videos and Haynes manual I looked in didn't have anything. Thanks in advance. Lastly. Just did front brakes. And now seems like one side won't "let go". I smell the brake rubbing and when I should be coasting it stops me. Not bad. But enough to worry. Thanks again
rug_15 is offline
post #2 of 4 Old 04-30-2013, 07:27 PM Thread Starter
rug_15
Just to elaborate. Te manuals didn't say anything about a crush seal. The yoke had a small grove In it. But didn't think it would do anything. And brakes were fine right after I changed them. Just started doing this today
rug_15 is offline
post #3 of 4 Old 04-30-2013, 09:04 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Either the seal is wrong, defective, picked up a tear in installation, or it's the groove on the yoke. As for the crush sleeve, you need it. It is located between the pinion bearings and holds the rotational/bearing play torgue after setting it during a rebuild.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #4 of 4 Old 05-01-2013, 04:50 AM Thread Starter
rug_15
So I should replace the yoke and go from there? Q tech has them cheap. But they also have the whole rebuild for 100$. But not sure if I "need" to change the gear or crush sleeve? How do I tell...
rug_15 is offline
