pinion preload Help - JeepForum.com
post #1 of 9 Old 05-10-2012, 10:27 PM Thread Starter
jeepjoe4
pinion preload Help
I just did a regear on a dana 30 and I used a crush sleeve, when I was setting the preload I over shot the max torque setting by 2 to 3 INLBS, I am thinking of running it as is, Am I going to regret this decision or should i redo the preload? I have all the parts just not the time to redo it should i just let it sit till I can get to it or should i chance it?
jeepjoe4 is offline
post #2 of 9 Old 05-11-2012, 06:48 AM
rjbruzan
Run it.
rjbruzan is offline
post #3 of 9 Old 05-11-2012, 08:20 PM
danb303
What was your preload?
New bearings? or old ones?
danb303 is offline
post #4 of 9 Old 05-11-2012, 09:25 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Originally Posted by rjbruzan View Post
Run it.
I agree, a couple of IN/LBS won't make a difference.
jeepdaddy2000 is offline
post #5 of 9 Old 05-12-2012, 11:54 AM Thread Starter
jeepjoe4
My preload is at 43 IN LBS and the are new bearings
jeepjoe4 is offline
post #6 of 9 Old 05-12-2012, 12:06 PM
Jason
IMO, that's too much. I set mine at 18-19 when I regeared.
Jason is offline
post #7 of 9 Old 05-12-2012, 09:05 PM Thread Starter
jeepjoe4
sorry but the service manuel torque specs is as follows
WRENCH TIGHTENING TORQUE SPECIFICATIONS
LBS. FT. 1 Nm
Cover Screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 47.5
Differential Bearing Cap Screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 108.5
Drive Pinion Nut . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 470 637.2
Fill Plug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 33.9
Ring Gear Screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 220 298.3
PINION BEARING AND DIFFERENTIAL BEARING
PRELOAD SPECIFICATION
LBS. FT. 1 Nm
Torque to Rotate Drive Pinion Only (New bearings only) . . . . . . . . . . . . . . . . . . . . . 20-40 <- in LBS <<<<<<<<<<<<<<<<
Torque to Rotate Drive Pinion and Differential Case
Assembly (Less Axle Shafts) (New bearings only) SEE NOTE 1
BACKLASH SPECIFICATION
Drive Gear to Drive Pinion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 005 - .008 (.13 -20 mm)
jeepjoe4 is offline
post #8 of 9 Old 05-12-2012, 09:20 PM Thread Starter
jeepjoe4
going to run them, If i have any problems I'll just have to park the Jeep till I can get to it. I'll keep you all updated
jeepjoe4 is offline
post #9 of 9 Old 05-29-2012, 09:52 PM Thread Starter
jeepjoe4
Ok all is great, after breaking in the gears I drove my Jeep 1100 miles to Denver with no problems from the axels but I did get a wired vib from the trans (auto) and it is getting really hot I have it in a shop out here and they are not having any luck finding the problem.
jeepjoe4 is offline
dana 30 regear
took pinion nut off without measuring preload... Ripper3494 Engines & Drivetrain 1 11-17-2011 03:28 PM
Pinion preload help (d44a) gatorayde Engines & Drivetrain 0 03-05-2010 03:11 PM
pinion preload sitdwnandhngon Engines & Drivetrain 15 06-25-2008 09:13 AM
Who here knows how to adjust pinion preload? fisher836 Engines & Drivetrain 9 12-07-2006 11:44 AM
9" pinion preload jeep795 Engines & Drivetrain 6 12-06-2006 03:57 PM
