pinion angle - JeepForum.com
post #1 of 4 Old 02-16-2008, 09:49 AM Thread Starter
red02x
pinion angle
How do you find the correct pinion angle? and how do you know its the correct angle. I know there is an angle finder that you can find at the home depot, but is there a formula for diffrent size lifts or a certain degree for the diffrent size lifts. What is the number that you need to get to have that correct angle?
If I were to put a coil spacer under the 4.5 coils would it change the angle in a major way?
Just curious because I have a 4.5 re sa lift and have a slight vibe in the range of 30-40 mph. I dont have a sye/cv but want one. I also want to put the acos coil spacers in. Should I put the coil spacer in before I get the sye/cv or does it matter?
Thanks again
red02x is offline
post #2 of 4 Old 02-17-2008, 09:40 AM
Zlake
Zlake's Avatar
So here is a link to Tom Woods website that tells about angles. Clicky. Personally I would have done the SYE/CV when I did the 4.5 SF and I would def. not go higher before I got that done. It may not bother you much but you are causing undue stress on a lot of parts if you just leave a vibration and it will eventually take its toll.
And to actually set the angle on the pinion/driveshaft you have to lengthen/shorten the upper control arms to set it. Hope that helps.
Matt
Zlake is offline
post #3 of 4 Old 02-17-2008, 12:24 PM Thread Starter
red02x
sounds good matt, Thanks for the link.
red02x is offline
post #4 of 4 Old 02-18-2008, 02:41 PM
jeeptillidie
jeeptillidie's Avatar
jeeptillidie is offline
setting pinion angle 3xratedxj General Jeep & Off-Road Equipment 0 04-04-2009 12:02 PM
Pinion angle? Runnerboy Engines & Drivetrain 4 04-06-2007 06:36 PM
need help finding my pinion angle EMT Engines & Drivetrain 1 07-23-2006 11:51 AM
Pinion Angle? wherndon Tires & Wheels 2 05-20-2005 11:42 AM
set front pinion angle rustyCJ General Jeep & Off-Road Equipment 5 08-01-2003 10:41 AM
