Performance upgrade - JeepForum.com
post #1 of 6 Old 02-19-2003, 06:26 PM Thread Starter
Daddybone
Performance upgrade
Hello all, looking for some advice here. I have a 2001 Grand Cher. Limited 4.7 liter. Iam looking to add some minor upgrades that will give me some extra power (that i will notice). I have heard that I might not notice a new intake. What are some other options I have with out doing something to void my warranty.
Thanks
Daddybone is offline
post #2 of 6 Old 02-19-2003, 06:43 PM
hjeepxj
hjeepxj's Avatar
4.7 V8 (Factory ratings 235hp@4800rpm/295lbft@3200rpm)
1. K&N FIPK: 5hp/6lbft
2. Kolak 3" cat-back exhaust: 5hp/6lbft
3. Modified Y-pipe + 3" high-flow cat: 10hp
4. Mopar Performance PCM flash: 9hp/8lbft
5. ASE chip: -5hp/21lbft
6. Flometrics 70mm TB: 5hp/7lbft
7. Speedtweaks IAT adjuster: ?
8. KRC Performance HO camshafts & intake manifold: 19hp
9. Remove clutch fan + short belt PS/alternator bypass: 10hp/17lbft
10. Duner's fuel rail cooling system: 16hp/29lbft
With the above mods, output should be about 300hp. Now the big stuff:
11. Kenne-Bell supercharger: 99hp over stock
12. Paxton Novi-1000 supercharger: 102hp/62lbft over stock
13. Garrett T04B turbocharger 10psi boost: 144hp over stock
14. Nitrous Express kit: 50-150hp over stock
4.7 HO V8 (Factory ratings 265hp@5200rpm/325lbft@3600rpm)
1. K&N panel filter: 3hp
2. K&N FIPK: 7hp
3. Kolak 3" cat-back exhaust: ?
4. Modified Y-pipe + 3" high-flow cat: ?
5. ASE chip: ?
88 Jeep Cherokee, Lots of Mods.
hjeepxj0.tripod.com
"Im okay, im alright, just might get a little high tonight, im okay, im alright, CARRY ON!"
-Pat Green
hjeepxj is offline
post #3 of 6 Old 02-19-2003, 06:47 PM Thread Starter
Daddybone
Thanks
HJeepXJ,
Thanks for the great info. Is one of those items in there an Intake system?
post #4 of 6 Old 02-19-2003, 08:42 PM
hjeepxj
hjeepxj's Avatar
Re: Thanks
Originally posted by Daddybone
HJeepXJ,
no problem, the first one is an intake system
hjeepxj0.tripod.com
-Pat Green
hjeepxj is offline
post #5 of 6 Old 02-22-2003, 05:42 PM
dontpush
dontpush's Avatar
i have a 2000 tj 2.5L bone stock(except for 30" tires). how does the k&n air intake system perform off roading? will water-mud effect it? should i replace the factory intake-filter?
dontpush is offline
post #6 of 6 Old 02-22-2003, 07:09 PM
hjeepxj
hjeepxj's Avatar
water and mud will effect it, although you could make a water sheild, basically sealing it off from the bottom side
if you do a lot of mudding and water crossings, id reccomend just a replacement air filter
hjeepxj0.tripod.com
-Pat Green
hjeepxj is offline
Want to stealth upgrade my previous audio upgrade Peregrine777 Audio, CB & Ham Radios, GPS, & Electrical 17 12-30-2009 07:33 PM
225 v6 performance upgrade? silentknight Engines & Drivetrain 5 10-31-2009 12:43 PM
"Performance chips" OBD2 plug in fpr 4.O L6, jet performance, whats the deal? jamoka3 Audio, CB & Ham Radios, GPS, & Electrical 6 10-27-2009 11:35 AM
TJ Performance Upgrade...? thejafe Tires & Wheels 1 11-07-2003 01:27 AM
Performance ECU Bryan Engines & Drivetrain 1 02-14-2002 08:05 PM
