performance ignition systems? - JeepForum.com
post #1 of 5 Old 02-13-2003, 10:33 AM Thread Starter
GREGDOG95YJ
GREGDOG95YJ's Avatar
I have a 4 banger in my jeep. I was averaging 19-21 mpg and it dropped to around 15-16 and started running rough so I replaced the O2 sensor and the plugs, wires, cap and rotor. the motor started running better but the mileage is still around 17. with gas prices climbing I am trying to figure out the problem. and I'm looking for suggestions.
Could it be:
1) the map sensor
2) the clogged cat
3) the TPS sensor
4) the fuel pressure regulator
5) a bad distributor
6)EGR valve
7) crank postion sensor
8) bad coil
9)IAC valve
also I have thought about getting a after market distributor and/or ignition system what would you guys recommend.
1) jacobs
2) MSD
3) mallory
4) HEI (if available)
5) Accel
6) DUI (Davis United Ignitions)
TIA
Jason Gregory
95 yj Rio Grande 2.5L
31" BFG MUDS, 1"BL,2" homemade spring lift, 150W KC'S, KN Filter, both air restricters gone, track bars gone, quick discos, & high flow cat
"just like all addicts my need to satisfy my addiction far exceeds my wallet!!"
GREGDOG95YJ is offline
post #2 of 5 Old 02-14-2003, 07:28 AM
wildvan
I dont have a good answer your question on the ignition, I am reserching them also, as for the mileage. Did any one thing start making it run bad, if it was running real rich, then you may have plugged up your cat, I have never heard of a coil going bad and still working, if the jeep runs, your coil most likely is working. Are you getting any check engine lights? Have you checked the codes??
You nned to do that, most of the time if your sensors start going, they will trigger a light.
wildvan is offline
post #3 of 5 Old 02-17-2003, 11:53 AM Thread Starter
GREGDOG95YJ
The check engine light is not on or coming on there are no codes stored in the computer. and the cat is only a year old. thats why I'm stumped.
Jason Gregory
post #4 of 5 Old 02-17-2003, 06:40 PM
wrangler john
I need more information.....what year wrangler?? Have you checked your ignition timing? checked compression of all 4 cylinders? Had you changed anything prior to this happening?
Some people thing 1 jeep is enough, But I had to have 3!!!
wrangler john is offline
post #5 of 5 Old 02-18-2003, 07:22 AM Thread Starter
GREGDOG95YJ
I checked the timing and it was at 12 degrees over. I have a 95 yj with a 4 cyl like it says in my sig. I have been trying to find a friend that has a compression tester so I can test compression. I had not changed anything I had been running the same setup for over a year when it suddenly changed and I have been chasing the problem ever since.
Jason Gregory
"Performance chips" OBD2 plug in fpr 4.O L6, jet performance, whats the deal? jamoka3 Audio, CB & Ham Radios, GPS, & Electrical 6 10-27-2009 11:35 AM
Let me see you cj systems! RollingOn33s Audio, CB & Ham Radios, GPS, & Electrical 0 02-28-2009 12:33 PM
Performance Ignition coil DTorres1978 Street Jeep Forum 10 01-08-2008 02:57 AM
Wiring Painless Performance Ignition Start Button BigJeepJay Audio, CB & Ham Radios, GPS, & Electrical 2 03-09-2007 06:53 AM
Co2 systems? DaveFL General Jeep & Off-Road Equipment 16 11-05-2005 06:29 PM
