Park problems - JeepForum.com
post #1 of 9 Old 04-26-2012, 07:52 AM Thread Starter
Ricke92cj
Park problems
I have a 97 with the auto tranny and have intermittent problems with it not wanting to shift out of park. It doesn't always seem to engage to park paw and after rolling it backwards or forwards til it clicks, it then will shift out just fine. Is there another adjustment inside the tranny to fix this without tearing it all apart?
Ricke92cj is offline
post #2 of 9 Old 04-28-2012, 09:09 AM Thread Starter
Ricke92cj
Nothing?
post #3 of 9 Old 04-30-2012, 05:51 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
From Joe Peters and well stated. Sounds harsh but just makes sense:
“Let’s play a game.
You pretend that you are the only one that knows what year/engine, etc that you are asking about.
We will all pretend you never asked a question until you provide at least the bare minimum of information about your vehicle”.
cruiser54 is offline
post #4 of 9 Old 04-30-2012, 11:56 AM Thread Starter
Ricke92cj
It's a 1997 Jeep Wrangler "TJ" with the 4.0 liter and the automatic tranny.
post #5 of 9 Old 05-01-2012, 12:13 AM
jnicewan
There isnt an adjustment in the trans but something could be loose or bent in there. Have you tried adjusting the shift cable yet? If the shift cable is not adjusted properly it could cause a problem going in/out of park and I would also suspect a possible problem with starting in park too.
jnicewan is offline
post #6 of 9 Old 05-01-2012, 02:58 AM Thread Starter
Ricke92cj
I've adjusted the cable a couple of times thinking that maybe I wasn't getting it right. I haven't yet had any problems starting or getting the key out when in park. I'm also thinking about changing the cable because the guy before me had the tranny rebuilt and I'm wondering if the cable got stretched.
post #7 of 9 Old 05-01-2012, 03:02 AM Thread Starter
Ricke92cj
I am suspicious on the rebuild though, because the fluid was quite dirty when I got it and the cooler lines where leaking from shoddy repair work.
post #8 of 9 Old 05-03-2012, 12:44 PM Thread Starter
Ricke92cj
“Let’s play a game.
Well I did what you asked, still nothing?
post #9 of 9 Old 05-03-2012, 12:47 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
My area of expertise does not cover your era of vehicle. As to why others have not responded, I cannot answer.
