-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   P0304 P0300 Leak-down and compression test results (http://www.jeepforum.com/forum/f19/p0304-p0300-leak-down-compression-test-results-2075705/)
NizmoTJ 02-05-2014 12:24 AM
1999 Jeep Cherokee sport 4.0 AW4
So I have been getting p0304 and p0300 CELs every once in a while. It seems to go along with rough idle at times. When its under load it feels fine. I'm riding on 37" tires so its pretty slow to begin with, never noticed a significant decrease in power. I decided that after doing some research on the forums I would try a leak down test and compression test. Here are the results:
LD.............C-D.C-W
#1 - 5%....148 160
#2 - 5%... 159 170
#3 - 29%..145 156
#4 - 41%..135 151
#5 - 7%....165 170
#6 - 8%....151 170
So as we can see from the leak-down, there are problems in cylinder #3 and #4. When doing the leak down, both cylinders had leaking out of the exhaust pipe. All cylinders showed minimal leaking out of the crankcase, it was barely noticeable though. I was planning on just buying a reman head from www.headsonly.com . Comes with valves and springs preinstalled for $345 shipped. I thought that until I did the wet compression test on cylinder 3 and 4. By the way, the wet test was done warm and with a capful of oil. Now I'm not sure what to think.
What would you guys do with this engine?
The time now is 09:27 PM.
