P0031, P0136, P0051 Check Engine Light - JeepForum.com
post #1 of 4 Old 02-07-2009, 07:44 PM Thread Starter
SLFalcon
2003 WJ
Hey Jeep Forum users!
I have a check engine light on my Jeep, and it is throwing three codes:
P0031 - O2 SENSOR 1/1 HEATER CIRCUIT LOW
P0051 - O2 SENSOR 2/1 HEATER CIRCUIT LOW
P0136 - O2 SENSOR 1/2 Circuit Low Voltage
Could this be three bad sensors, or is this a larger problem. I know which sensors these are, but I do not believe that is the issue.
Thanks in advance!
Josh Vallender
SLFalcon is offline
post #2 of 4 Old 02-10-2009, 08:46 PM Thread Starter
SLFalcon
2003 WJ
BUMP!
SLFalcon is offline
post #3 of 4 Old 02-10-2009, 09:23 PM
racerdude_9
check your wireing. maybe u got a loose connection. do some google searches on your code. maybe your dirty cat converter is messing with your sensors. or replace the sensors and see what you get. idk shooting in the dark but those are the first 3 things id do.
-1998 cherokee xj limited.. current daily driver.
-1991 dodge w250 cummins.. old daily driver and regular tire burner
racerdude_9 is offline
post #4 of 4 Old 07-12-2010, 04:19 AM
LKrux
first check a wire loom about an inch thick that rests on a stud popping out of the engine block. this stud can wear the loom and cause shorts. Inspect wiring closely.
these wires are towards the back of the motor near the firewall.
check if any o2 sensors have shorted out by wires touching the exhaust
if good then,
you need 2 upstream o2 sensors and 1 downstream sensor
p0051 &p0031 are upstream
p0136 is down
and check ecu for rust n stuff(wires)
peace brotha
4.0, 5sp, bfg33's, 3 1/2 lift
LKrux is offline
02 sensor , oxygen sensor , p0031 , p0051 , p0136
Check engine light haterasfever Engines & Drivetrain 4 07-08-2012 09:23 AM
check engine light on... Gas cap?? OffroadPrincess Engines & Drivetrain 4 02-07-2010 04:01 PM
check engine light tlking6 Engines & Drivetrain 3 05-05-2008 08:00 PM
check engine light on drm822 Engines & Drivetrain 1 11-01-2006 10:01 PM
I6 check engine light Chrisca Engines & Drivetrain 1 03-04-2005 05:28 PM
