over heating problems - JeepForum.com
post #1 of 12 Old 11-01-2013, 02:09 PM Thread Starter
XJnate
1989 XJ Cherokee
I'm having a HUGE problem with my 1989 Cherokee over heating..I know these have a crappy cooling system..I have replaced the thermostat, reservoir, radiator hoses, heater hoses, and water pump..I have had over heating problems ever since I got it but just recently replaced those things I just mentioned..I have gotten the air out of cooling system..the heater core is good and so is the radiator..here's the thing, its not really running hot now but every time I drive it and then park it all my coolant ends up on the ground, coming from the reservoir..I can't get it to hold pressure..is there any I can do to fix this? I've heard a 1990 S10 radiator fits perfect in there and I can do away with that BS plastic tank..but as of now funds are limited and can't find one fairly cheap..if anyone could please throw me some ideas thst could be helpful I would greatly appreciate it..thanks
XJnate is offline
post #2 of 12 Old 11-01-2013, 03:27 PM
jokerchief462
Did you get the right water pump they are directional.
V belts clockwise or normal rotation
Serpentine belts are Reverse
Check it out could be the issue
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 12 Old 11-01-2013, 04:28 PM Thread Starter
XJnate
1989 XJ Cherokee
Yeah I got the right one..I have been messing with this thing for weeks now, everyday..is there another reservoir that could be used??
XJnate is offline
post #4 of 12 Old 11-01-2013, 04:45 PM Thread Starter
XJnate
1989 XJ Cherokee
Something else odd, it doesn't start gushing water as soon as I cut it off, it wait til the heater core opens/closes then it starts..so I obviously know its not holding pressure but I have checked everywhere where pressure should be and no leaks..it just keeps coming from the bottle cap..
XJnate is offline
post #5 of 12 Old 11-01-2013, 05:01 PM
holysirsalad
So it's not actually overheating while operating, but you park it and the pressure bottle's pissed everywhere?
I take it you are still on the original cooling system with the pressure bottle and have not done the swap to the Chrysler "open" system. If you have the original silliness, upgrade for the bottle cap is part number 703-1396.
holysirsalad is offline
post #6 of 12 Old 11-01-2013, 05:54 PM
uberxj92
1992 XJ Cherokee
Your best bet is to swap in a radiator out of 91 up xj. They sell a kit at parts stores for hooking the 2 hoses together where the old bottle is. You can get an overflow there too. This will give you a radiator cap. You may also look into electric fan swap too.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #7 of 12 Old 11-01-2013, 06:04 PM Thread Starter
XJnate
1989 XJ Cherokee
I def plan on doing that upgrade with the 91..thanks a lot for that advice..since funds are tight right now ill try the cap til I can get the cash for the full upgrade..
XJnate is offline
post #8 of 12 Old 11-01-2013, 06:42 PM
uberxj92
1992 XJ Cherokee
When you do that drill 2 small 1/4 holes in the tstat.
uberxj92 is offline
post #9 of 12 Old 11-01-2013, 07:36 PM Thread Starter
XJnate
1989 XJ Cherokee
Will do..thanks again..goin tomorrow to get that cap..hope it works for the time being..
XJnate is offline
post #10 of 12 Old 11-02-2013, 10:03 AM
blackolive99
My 87 still runs with factory cooling system.
New radiator, tstat, tstat housing, pump, hoses, bladder bottle AND a new bottle cap. The cap makes it hold pressure till it cools down. I dont mind the old system. It works.
blackolive99 is offline
post #11 of 12 Old 11-02-2013, 11:16 AM Thread Starter
XJnate
1989 XJ Cherokee
holysirsalad thank you so much for that suggestion bout that cap..I just burpped the jeep and put the new cap on and so far its working..this will def hold me over til I get that upgrade..thanks again guys..
XJnate is offline
post #12 of 12 Old 11-02-2013, 11:42 AM
holysirsalad
No problem. Courtesy of Renix man cruiser54
