Opinions - FlowKooler High Flow Water Pump? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Opinions - FlowKooler High Flow Water Pump?
NOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineROCKRIDGE 4WD Supports our Service Members! Military Disc
Unread 09-24-2006, 03:36 PM   #1
Joe-n-TX
Well, I've got a slow leak in my radiator core. I figure it's time to replace it. It looks original ('84) and it's got a bad gouge in the center from where the fan chewed into it sometime during it's previous ownership (scares me just looking at it).
So, in addition to replacing the core I think I might go with the FlowKooler High Flow water pump while I'm at it.... and new hoses and themostat.
Anyone have any pros/cons with FlowKooler?
Thanks in advance!
Joe
84 CJ7 258 T5
Joe-n-TX is offline   Reply With Quote
Unread 09-24-2006, 03:59 PM   #2
Talos
I installed a FlowKooler a few years ago along with a Flex-A-Lite and new 3 row radiator and the combination keeps things nice and cool, but I live in the PNW where it never really gets very hot. Be sure to get a wire reinforced lower radiator hose if you do get the FlowKooler.
I think beefing up the cooling system like you're planning is a good idea anytime especially when going with lower than stock gears.
Talos is offline   Reply With Quote
