OldManEmu YJ lift questions. - JeepForum.com
post #1 of 2 Old 09-25-2012, 12:52 AM Thread Starter
xxxxxxxTunesUpTopDown
Guest
I'm considering Old Man Emu heavy load leaf springs for all four corners (I heard that the front and rears are transferable because they're identical) of my 93 4.0 wrangler with NitroCharger shocks and the bushing for the springs. Also some steel-braided brake lines and steering stabilizer eventually. First off. If I buy these things, based on anyones expirience or observations/opinions, will I need any further mods? Transfer case drop. Slip yoke elim etc. Can I buy the springs, shocks and bushings (initailly, like for the next few months) and stop there for a while? Also, when I google "old man emu yj leaf springs" the only decent website that comes up is "quadratec". Anybody have any expirience with this website or suggest an alternative. Any thoughts on the topic are appreciated!
xxxxxxxTunesUpTopDown is offline
post #2 of 2 Old 09-25-2012, 06:58 PM
NonRubicon
Aside from the core components (springs/u-bolts/shocks/bushings and maybe shackles), you might need to deal with driveline vibes. There's no way to know until you install the lift and drive the Jeep. Some people need the further adjustment to the drive line angles using different shims or a t-case drop or a SYE, others can get by without. I personally didn't need to install the t-case drop as I don't have any vibes. Getting a SYE/CV drive shaft is certainly an upgrade worth it should you have the money, but a t-case drop is usually sufficient to get by until you can afford the SYE. I bought a t-case drop kit but ended up not needing it.
I bought my OME lift through Quadratec as they had all the parts I needed. They goofed on my lift order and failed to ship one of the OME shackle pairs I purchased. Once I contacted them (unfortunately I had to wait through the weekend), they made good and got the missing parts to me, three day shipping at no additional charge. Definitely check your bill of lading to make sure you get all the parts you order.
NonRubicon is offline
