old cj 258 running rough - JeepForum.com
post #1 of 5 Old 04-02-2008, 12:14 PM Thread Starter
sparctacus
My CJ started running extremely rough the other day. I drove it work jsut fine. But going home it wouldn't idle, and would die if I slowed down for the corners or came to a stop sign.
I've checked distributor cap + rotor, wires, and plugs, all which I just installed in December and show no signs of wear at all. I've taken the fuel filter out and run without it to test that, I've run seafoam through the tanks + carb.
I've adjusted the fast idle screw to keep it sort of running while driving it around, but am kind of at a loss as to my next (hopefully cheap) step.
The only thing I've found wrong is that it's about 1/2 quart overfull on oil.
sparctacus is offline
post #2 of 5 Old 04-05-2008, 11:45 PM Thread Starter
sparctacus
I *think* I've narrowed this down to the cam position sensor a trip to the junkyard yeilded no results. Anyone got a distributor left over from an electronic upgrade?
post #3 of 5 Old 02-19-2010, 01:04 PM Thread Starter
sparctacus
an update for the archives. This turned out to be a worn lobe on the cam.
post #4 of 5 Old 02-19-2010, 01:21 PM
JOExFROMxNY
did you change out the motor?
JOExFROMxNY is offline
post #5 of 5 Old 02-19-2010, 02:25 PM Thread Starter
sparctacus
No, just the cam.
Bloody Forhead ('94 ZJ 5.2L running rough) ScottN3N Engines & Drivetrain 4 05-19-2012 07:36 AM
85 XJ 2.5 tbi running rough need ideas. TwistedEvo8 Engines & Drivetrain 0 02-18-2009 02:43 PM
AMC 258 4.2L Straight 6 on 73 Commando Running Rough 73CommandoKEYWE Engines & Drivetrain 1 09-22-2008 04:23 PM
Running Rough / Popping noise dunvillekid Engines & Drivetrain 0 06-08-2007 01:25 AM
87 2.5 running rough 79cherokee Engines & Drivetrain 1 07-16-2006 09:31 PM
