Ok to use 5w-30 in 4.0? - JeepForum.com
post #1 of 15 Old 03-06-2013, 06:02 AM Thread Starter
TimV
As the thread title states, is it OK to use 5w-30 in the 4.0? I normally use 10w-30, but just used up my stash in the wife's car. I have a whole case of 5w-30 here, and the only vehicle that takes it is up for sale. If it's a no go, I'll stop being cheap and go buy some, but I'm hoping to be able to use what I already have.
It's not an addiction. It's a way of life.
TimV is offline
post #2 of 15 Old 03-06-2013, 07:24 AM
biffgnar
biffgnar's Avatar
I'd use it and wouldn't worry a bit.
Romney in 2020!
biffgnar is offline
post #3 of 15 Old 03-06-2013, 09:35 AM
TJjeepguy
I used 5w-30 in my 4.0 TJ the whole time I owned it (~28,000 miles) and I never ran into any issues. The previous owner may have been running It as well. I'd say go for it.
WTB
-TJ Flat Fenders
-ZJ Tie Rod
-Rear TJ Fender Flares
TJjeepguy is offline
post #4 of 15 Old 03-06-2013, 09:36 AM
mike_dippert
mike_dippert's Avatar
5w-30 is recommended in the owners manual for <50 temps. 10w-30 for 30<. It won't hurt a thing.
mike_dippert is offline
post #5 of 15 Old 03-07-2013, 02:45 AM
seattle_yj
Used it in the same jeep for the last 15 years. I wouldn't use anything else.
seattle_yj is offline
post #6 of 15 Old 03-09-2013, 11:32 AM
JeepComanche89
1989 MJ Comanche
What about 10-40?
JeepComanche89 is offline
post #7 of 15 Old 03-09-2013, 01:53 PM
seattle_yj
Originally Posted by JeepComanche89
What about 10-40?
It's too thick for me, I would get lifter tick. Unless its winter and you live in a cold climate I would use thinner oil.
post #8 of 15 Old 03-09-2013, 04:14 PM
JeepComanche89
1989 MJ Comanche
Thanks
post #9 of 15 Old 03-12-2013, 06:40 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by JeepComanche89 View Post
Thanks
More importantly, do not use cheapie oil filters. Use Wix, Napa or Mopar.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #10 of 15 Old 03-12-2013, 01:52 PM
ajmorell
ajmorell's Avatar
What about 10-40?
It's fine. I ran it for years in my 4.0
That doesn't make sense. A thicker oil helps to reduce lifter tick
ajmorell is offline
post #11 of 15 Old 03-12-2013, 10:24 PM
seattle_yj
It makes perfect sense, thicker oil takes longer to lubricate and circulate from cold to warm. Thinner oil does not. This is my experience and opinion, you do what you want.
post #12 of 15 Old 03-13-2013, 09:26 AM
ajmorell
ajmorell's Avatar
Thinner oil also bleeds down faster, which is what causes lifter tick. If you were worried about cold lubrication run 5w40, it's the same viscosity as 5w30 at ambient temp.
ajmorell is offline
post #13 of 15 Old 03-13-2013, 01:07 PM
seattle_yj
I dunno man. I would say that it's the combo of valve build up and thick oil making it all stick together. That's just my opinion, I have no science backup except that it I have found that it works in Benz, yota, and jeep engines.
post #14 of 15 Old 03-17-2013, 09:58 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
your in a cold climate area.. 5W30 should be great in your 4.0...
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #15 of 15 Old 03-19-2013, 04:58 PM Thread Starter
TimV
I already changed it out and used 5w-30. Runs exactly the same. I'll change it out again next year after another 4k miles.
TimV is offline
