oil slinger - JeepForum.com
post #1 of 7 Old 04-29-2013, 07:25 PM Thread Starter
picurn
1978 CJ5
oil slinger
I hope I hear the answer I want. I have pulled my 258ci for a little freshing up. After repalcing the RMS, timing chain and gears, various other things with all new seals and gaskets. I have it all together ready to put it back in its place, when I noticed the oil slinger on the bench My question is do I really need to tear this thing down again and put the slinger on or can I carry on without the oil slinger?
thanks.
picurn is offline
post #2 of 7 Old 04-29-2013, 07:33 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Although you may be able to "get away without it", it does serve a purpose.
I know, not the answer you wanted to hear.....
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 7 Old 04-29-2013, 08:53 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
FWIW, 4.0s in later model years didn't have the slinger. I guess you could try running it without it.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #4 of 7 Old 05-01-2013, 06:57 AM
Newtons3
Newtons3's Avatar
If your seal and seal surface are good you wont have any problem.
Newtons3 is offline
post #5 of 7 Old 05-01-2013, 07:10 AM Thread Starter
picurn
1978 CJ5
That's the answer I was looking for. It's going back in the way it is. I know if I jack with it now that oil pan will leak for sure.
picurn is offline
post #6 of 7 Old 05-01-2013, 08:04 AM Thread Starter
picurn
1978 CJ5
thanks for the input
picurn is offline
post #7 of 7 Old 05-01-2013, 08:14 AM
Newtons3
Newtons3's Avatar
No problem
Newtons3 is offline
