Oil recommendation - JeepForum.com
post #1 of 19 Old 09-09-2013, 05:43 AM Thread Starter
AIRBORNE
Oil recommendation
My WJ is new to me. It has 153,000 on the odometer. I wanna get recommendations on what oil I should start using in it. My last WJ I used Valvoline High Mileage. I've heard synthetic isn't always good for older engines. Any advice is appreciated.
2000 Grand Cherokee Limited/ Quadra Drive / 4.0L/ OME HD springs, Bilsteins, JKS trackbar, 255/75/17 BFG M/T with JK Moabs
2005 Silverado 2500 HD Duramax
United States Army (2004-present)
AIRBORNE is offline
post #2 of 19 Old 09-09-2013, 06:03 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That synthetic story is lilke a bad fart. Keeps floating around.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 19 Old 09-09-2013, 06:10 AM
BIGBADWOLF
Don't lose sleep over this,any oil recommended in the owners manual will be OK. The 4.0 is basically a tractor engine so many people with high mileage use a diesel/industrial/fleet oil such as Rotella,Walmart, Tractor supply 15-40 weight.
BIGBADWOLF is offline
post #4 of 19 Old 09-09-2013, 06:43 AM Thread Starter
AIRBORNE
AIRBORNE is offline
post #5 of 19 Old 09-09-2013, 06:54 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by AIRBORNE View Post
That switching to synthetic in a high mileage engine causing issues like leaking etc.
post #6 of 19 Old 09-09-2013, 07:24 AM
jp360cj
1977 CJ7
The reason people (including myself) run diesel oil in older gas engines is basically because it's more similar to the oil that was around when the engines were designed than modern oils.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is online now
post #7 of 19 Old 09-09-2013, 08:36 AM
BIGBADWOLF
Yes and also because it is high in zinc and has excellent detergent cleaning properties. Zinc is beneficial to flat tappet lifters of old engines. Diesel oil has the extra detergents that will keep the 4.0 clean. The 4.0 is more related to a diesel than a modern overhead cam, close tolerance engine.
post #8 of 19 Old 09-09-2013, 08:50 AM Thread Starter
AIRBORNE
Rotella is good oil. I use it in my Duramax. They also have some Valvoline Premium Blue that is on sale now (made for diesel engine). I use 15W 40 in my Duramax. What weight would you recommend for the 4.0L?
AIRBORNE is offline
post #9 of 19 Old 09-09-2013, 09:35 AM
BIGBADWOLF
Again were talking personal preference but for that many miles I would feel comfortable with 15-40 and that is what wt I use.
post #10 of 19 Old 09-09-2013, 10:37 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
I run Mobile 1 or T6 5W30in my jeep, Rotella T6 5W30 in my powerstroke.
The synthetics have better additive packs to deal with going on longer change intervals. when I owned and drove big trucks (WL900, 387 pete, 379 pete, FLD 120 etc) I ran full synthetics and pulled an oil analysis at the recommended oil service interval and only changed it when it was needed. My Cat engines could go longer between changes (like 200,000 + miles) with simply changing the filters and topping off with fresh oil.
Lubrication technology has come a very long ways since even '93 which is when my YJ was born. Check out www.bobistheoilguy.com it is the JF of the oil world and has tribologists and real honest to goodness scientists that have fact based reviews and citations for there positions, not "well this is why I feel this is the best".
You'l likely never run another Fram oil filter after visiting that place....
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #11 of 19 Old 09-09-2013, 10:51 AM
schitzangiggles
King of Macastan
Motor oil 101 http://www.bobistheoilguy.com/motor-oil-101/
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #12 of 19 Old 09-09-2013, 11:33 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Oil is Oil, buy whatever is on sale. Most premium cost oils do not provide an extra benefit that makes them worth the added cost.
Your oil change interval is more important than the oil brand or type. I use 10w-40 in the warmer months and 5w-30 in the winter.
I do recommend good quality oil filters.
CJ7-Tim is offline
post #13 of 19 Old 09-09-2013, 11:59 AM
BIGBADWOLF
Originally Posted by schitzangiggles View Post
Your confusing the OP. The article is factual BUT you cannot buy old oil anymore....period. Rotella and wally world diesel oil both meet API latest specification which is M. The article you posted was older than that and the author said spec "L" was the latest and when spec "M" comes out it will be even better. Well, it is on the shelf now in all fleet brands so don't worry about it.
post #14 of 19 Old 09-09-2013, 04:05 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I thought you preferred this oil. LOL.
post #15 of 19 Old 09-09-2013, 06:15 PM
BIGBADWOLF
I've looked all over and cannot find it. Maybe I need to look at yard sales!
