Oil pressure switch question - JeepForum.com
post #1 of 6 Old 03-19-2002, 08:45 PM Thread Starter
CJ8DV8
Hey gang! Here's post #1:
Here's something that's been bugging me.
On the passenger side of my motor there's a T in the block with the oil pressure sending unit (for the dash gauge) and what looks like a pressure switch for an idiot light.
Here's the puzzling part: I don't ever recall seeing and oil pressure idiot light on my dash. To top it off, my local Jeep dealer found a need to run a hot lead from the fuse block to one side of this switch (bypassing the factory harness). I checked the cut wire and it had 12vdc. Why it was bypassed is another mystery.
Anyway, what is this switch for? If it is for an idiot light, perhaps it should be pointing to the one behind the steering wheel!
Black '83 CJ8
258 I-6
Auto
Half hardtop
Rustproof plywood floorboards and bed upgrade.
Lots of work, but working on it.
CJ8DV8 is offline
post #2 of 6 Old 03-19-2002, 09:53 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
I never found a use for this extra sending unit on my 79 CJ7 either. I just removed it and all is well.
Steve
OldJeepguy is offline
post #3 of 6 Old 03-19-2002, 11:20 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Just a thought, I lost an engine about 15 years ago after the line to the mechanical gauge broke(it's hard to see the gauge when you are trying to miss a tree on an ugly hill climb) .Didn't notice it until the lifters started clattering. Ever since then, I run an idiot light as well as the gauge.They are a snap to install and and when they light up you notice them!
bazinga
jeepdaddy2000 is offline
post #4 of 6 Old 03-20-2002, 11:20 AM
jeepcherokeev6
cj8dv8, im not sure about your jeep, but on my xj, the idiot lights arent very visible when that arent lit. i mean, you can not tell what they are, until their lit up.
just a thought
Dan, San Bernardino, California
'86 XJ, 2.8 V6 5 spd, 3" lift
"It may be a piece of sh**, but its MY piece of sh**!" -Me
jeepcherokeev6 is offline
post #5 of 6 Old 03-21-2002, 01:59 AM
jeepdaddy2000
1971 CJ5
I have an early CJ and the light is in the instrument cluster. It's fairly small but is a lot more noticable then a needle on "0". If you don't like the one you have then you can put your own light(as big as you want)anywhere on the dash that's easy to see.Get an isolated light(one that needs a 2nd wire to be grounded) from your local parts/RV house.run a wire from the switch through the light to the coil side of your ignition switch and it's done!
bazinga
post #6 of 6 Old 03-22-2002, 05:02 PM Thread Starter
CJ8DV8
Thanks Guys- I found some gauge troubleshooting instructions on a website that mentioned the mysterious switch... Seems that everyone's right. It said that in some gauge clusters that the switch is for an idiot light and in other applications it tells the computer that the oil pressure has reached 4 psi.
I'll take a closer look at my gauge cluster and if I don't see a light I'll assume it's for the computer.
Anyway, I figure it belongs there one way or the other. Thanks again.
Black '83 CJ8
258 I-6
Auto
Half hardtop
CJ8DV8 is offline
this look like a decent pressure switch willyb8 Fabrication Shop 32 01-08-2010 07:53 PM
busted pressure switch for OBA TJ_with_Tusks General Jeep & Off-Road Equipment 0 08-19-2009 07:15 AM
OBA Pressure Switch Wiring Help JJs99TJ General Jeep & Off-Road Equipment 4 09-24-2008 10:54 AM
Pressure switch river rat Audio, CB & Ham Radios, GPS, & Electrical 2 08-25-2005 05:58 AM
Air pressure cutoff switch river rat General Jeep & Off-Road Equipment 4 08-24-2005 07:22 PM
