Oil Pressure Swing - JeepForum.com
post #1 of 2 Old 08-18-2001, 12:22 AM Thread Starter
Leadfoot
Oil Pressure Swing
I've got a 93 Grand LTD - shes got 212000 on her, and I've got this problem with a huge swing in oil pressure. When you 1st start it, at idle, she's fine. Give her some rpm's and as the rpm's get higher - the oil pressure gauge will peak at 80psi, and come back to 50/60psi for idle. After shes warmed up - Idle shows 20psi and rpms will get her into the 50's consistantly. Is it time for a new pump, gauge or sensor?
Also - got seeping oil from the oil filter? No matter what I do - can't get it to seal - it is possible to replace only the area where the oil filter screws onto the block? Looks like is should come off - but can't get my big fat head in close enough to see!
Leadfoot is offline
post #2 of 2 Old 08-18-2001, 04:39 AM
Pantera
I bet the oil filter thingy is causing your oil pressure probs... Just a guess though... I may have the same problem with my 2.5... I'll be checking it tomorrow in my semi-semi-annual oil change...
Arent' these guys cute???
Eddie H.
91 YJ 4-Banger
Omaha, NE
Pantera is offline
What is the correct street tire pressure and off-road pressure? JeepinYahoo Tires & Wheels 84 04-11-2013 06:52 PM
Swing Away Dog Carrier Spectre66 Fabrication Shop 14 01-29-2009 07:49 PM
swing away question skrittles Fabrication Shop 7 11-26-2007 12:33 PM
swing hinge? Bigbob Fabrication Shop 7 03-22-2006 04:15 PM
Swing away plans townslo Fabrication Shop 3 08-27-2004 01:05 PM
