Oil Pressure on New Rebuild - Page 3 - JeepForum.com
post #31 of 35 Old 08-31-2013, 06:53 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Originally Posted by BIGBADWOLF View Post
The pump itself when it runs dry because most of the oil is being pumped to the top of the engine faster than it can drain back to the sump.
And that is why high volume oil pumps need larger base pans. Putting a high volume oil pump into an engine that has worn bearings is a waste of $$$. It is cheaper and just as effective to just use heavier oil.
Bottom line is once your clearances are too large it is time to at least swap out the worn main and connecting rod bearings along with a new stock oil pump.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #32 of 35 Old 08-31-2013, 07:41 AM
uberxj92
1992 XJ Cherokee
Originally Posted by cruiser54 View Post
Engine oil pressure has NOTHING to do with seal life.
4.0s did indeed use HV oil pumps in some applications for the military.
And what other important parts can be damaged by higher oil volume?
So you're telling me that seals can withstand infinite amounts of pressure for infinite amounts of time?
Did you install the larger capacity pan?
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #33 of 35 Old 08-31-2013, 10:39 PM
Flyordie
1985 XJ Cherokee
I did yes. Its got a dropped area right before the oil drain bolt.
Flyordie is offline
post #34 of 35 Old 09-02-2013, 12:14 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I am well aware of how the oil system works in an internal combustion engine. Oil doesn't get 'lost', it gets circulated because the system is designed to continuously pump the oil to through the system, kind of like the cooling system.
Actually, the oil does get "lost", or forced from the bearing surfaces (preferably by oil pressure), where it drains back into the pan, to be recirculated by the pump again. This is different from a sealed system, in which the lube stays in the bearing (but you already stated that below......)
Theoretically (that term has been used already) the engine could stay lubed with a closed pressurized system if the oil could stay cool and clean enough. That is too expensive to implement and hurts the oil dudes too much also.
The oiling system on a car is rudimentary. Maintain certain clearances and keep pumping oil through it
It is wildly impracticable to attempt to run a sealed pressurized system in a standard auto, and a non-pressurized (sealed bearing) system will not work for babbitt style bearings.
Why would you want that high of a pressure???? HV pump is overkill especially on a 2.5. All that does is take hp away from the drivetrain and puts stress on the cam. Its a psych thing.
Again, do not confuse a high volume pump with a high pressure pump.
Higher pressure in a pump is achieved with a heavier bypass spring. This can be achieved with both a stock or high volume pump. Generally, there is little reason to run higher pressure on a standard engine, as all you're doing is putting a strain on your cam and distributor drive gears.
Higher volume is achieved with larger gears. A high volume pump will push more oil at the same pressure when compared to a stock pump. This is important when running engines that may see very low RPM's. While a stock pump may be running a constant 40LBS at idle (550 or so), it may drop drastically at 250-350RPM's. This may be a problem with engines that encounter moments of very low RPM's lugging over a technical obstacle. A high volume pump will be able to maintain volume (pressure) at these low speeds due to the added amount of oil it is trying to pack into the journals. Many HV pumps come with one or more pressure springs (my Melling came with three) offering a variety pressures.
On a worn engine, many times a high volume pump will compensate for excessive clearances by pushing more oil into the voids. A high pressure pump will not be effective at this until the gears rotate fast enough to create the volume necessary to overcome bleedoff (loss).
Contrary to what is being said, neither a high volume or a high pressure pump needs a larger pan. Neither of these pumps can move more oil than the engine clearances will allow, with the excess oil being route back into the pan via the bypass valve.
jeepdaddy2000 is offline
post #35 of 35 Old 09-02-2013, 06:36 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The seals AREN'T under pressure except from the internal crankcase pressure air. No oil is pressure fed to seals on these engines.
The seals hold in "splashed" oil, not pressurized oil. That's why some of them have "slingers" right behind them on the crankshaft, to throw the splash away from them.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
