Oil Pressure Maxed out - JeepForum.com
post #1 of 4 Old 07-07-2001, 01:48 PM Thread Starter
cjfiver
My oil pressure gauge suddenly jumped up and began reading from 60 to 80+ psi. I was wondering if this is a common problem on 258 CJ-5s.
I was told to check the pressure relief valve, but I can't seem to locate it.
Any ideas?
cjfiver is offline
post #2 of 4 Old 07-08-2001, 05:26 PM
hamyscj
Do you have the factory electrical gage or a manual gage? If elec. put in another sending unit. If manual, try a new oil filter first. Your pressure relief is inside the oil filter adapter assembly.
One Way Up Racing
Romans 10:9
hamyscj is offline
post #3 of 4 Old 10-07-2001, 08:16 PM
B2hi
Check the pressure relief valve. I believe it is on the actually pump itself. If you have used any type of sealant recently it could have broke off and found it'd way to the pump. Also check for leaks. A rise in pressure usually is first sign.
87 Wrangler 4.2
Mopar MPI
4.0 Head
Throttle body spacer
K+N air filter
Con-ferr shackles,R.E. 4.5 lift with 33x12.5 BFG Muds and 1in. body
B2hi is offline
post #4 of 4 Old 10-16-2001, 09:03 PM
evilpsych
evilpsych's Avatar
i agree with hamy.. had the smae prob on my YJ.. replaced the oil pressure switch for the gauge on the engine block for liek $20.. dealer said they go sour all the time.. try that before you rebuild the engine..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
What is the correct street tire pressure and off-road pressure? JeepinYahoo Tires & Wheels 84 04-11-2013 06:52 PM
Low oil pressure 89 4.0 2500AK Engines & Drivetrain 2 12-18-2008 05:20 PM
304 low oil pressure schmoken Engines & Drivetrain 5 08-24-2005 10:44 PM
Air pressure JimJimmyJames Tires & Wheels 6 04-16-2005 09:30 PM
Oil pressure maxed??? Evildoer Engines & Drivetrain 1 06-10-2004 09:57 PM
