Oil pressure gone? - JeepForum.com
post #1 of 7 Old 03-17-2006, 06:07 PM Thread Starter
97wranglerkc
Oil pressure gone?
I was driving the faithful jeep yesterday when i noticed the check gauges light appear, and the oil pressure dropped to nothing, so scared to death, i parked it. i then changed the oil, the filter and sending unit. then i changed the oil pump and still nothing. last i attached a manuel gauge to the oil tank and started the jeep. it held pressue for about 5 minutes then it slowly started to decrease until it was reading 0 pressure. i am confused i only have 58,000 miles on my jeep so i should not be having trouble like this , or should i? please help me or give me any suggestions as to what you would do besides rebuilding it. i dont understand why i would need to do this at 58k.....please help, anything will be helpful.....thanks in advance
19wrangler97
rough country lift & 33x12.50 kumho M/T's
front-rear four-real bumpers,fogs
mile marker PE 9,000lbs winch,2 10' xplods, pioneer
clear corners, diamond plate rockers,marine radio
97wranglerkc is offline
post #2 of 7 Old 03-19-2006, 01:40 PM Thread Starter
97wranglerkc
come on....... nobody? this isnt helpfull at all. thanks alot
19wrangler97
post #3 of 7 Old 03-19-2006, 02:31 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Do you have oil in your coolant? When you replaced the oil pump, did you prime it? Is the cam in good shape? Is the oil pump full engaging with the cam/distributor?
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #4 of 7 Old 03-21-2006, 03:39 AM
TurboTJ
My buddy experienced simular problems with a 97. It turned out that there was a recall on his. The dealer replaced the fuel pump and it seemed it make the problem go away. This doesnt really make sense so i think they must have done something more. I would check with the dealer for recalls.
TurboTJ is offline
post #5 of 7 Old 03-21-2006, 08:41 AM
de6w6it
Usually a complete loss of oil pressure is due to the main bearings or the rod bearings....so the only thing I can think of, after reading all of what you have done so far, is that you spun a bearing somehow..., check with the dealership on recals, or warranty, hopefully, because it is not a quick or easy thing to fix. It is not too expensive to buy new bearings if you do it yourself, but since one may have spun, it may require some machining on the crank, or block, and this can get expensive.
'66 Mustang/200/C4/ground up resto
'88 4 runner/SAS/22re/W56/duals/31's DD
Build:
de6w6it is offline
post #6 of 7 Old 03-23-2006, 04:17 PM
Bonehead40
Jeep
You wiped the cam bearings! Water must have gotten into your crank case and wiped out your bearings. This will definitly ruin your engine. I have seen 7-8 of these in the last year. In every case, water damage. Did you buy your jeep used?
Bonehead40 is offline
post #7 of 7 Old 03-27-2006, 07:44 PM Thread Starter
97wranglerkc
yes and i recently went through a mud hole and it died. could water have gotten in through the muffler and exhaust went i started it back up and drove out?
19wrangler97
What is the correct street tire pressure and off-road pressure? JeepinYahoo Tires & Wheels 84 04-11-2013 05:52 PM
low oil pressure in 98 XJ Black89 Engines & Drivetrain 2 08-25-2006 11:24 AM
Air Pressure SCDolphin Tires & Wheels 6 02-28-2006 07:26 PM
304 low oil pressure schmoken Engines & Drivetrain 5 08-24-2005 09:44 PM
Air pressure afguy Tires & Wheels 5 07-26-2005 09:32 AM
