oil leeeak!!!! - JeepForum.com
post #1 of 8 Old 02-12-2011, 08:23 AM Thread Starter
xjpalmerie
oil leeeak!!!!
i havean 89 cherokee it is leaking oil, its cum from the blok under the oil filter. is that housing replaceable ?and wat could have caused the leak?
xjpalmerie is offline
post #2 of 8 Old 02-12-2011, 08:32 AM
mike481
mike481's Avatar
I'm sorry but I don't understand where the leak is. Are you saying it's coming from the base of the oil filter or near it or?????
The more specific you are the more somebody here will help you.
Mike
Chuck- A better dog than I could ever deserve
RIP 4-14-2012
mike481 is offline
post #3 of 8 Old 02-12-2011, 08:50 AM Thread Starter
xjpalmerie
yes its coming from near the oil filter, in the same houseing, its not the pressure valve,
post #4 of 8 Old 02-12-2011, 08:52 AM Thread Starter
xjpalmerie
almost like a huge outlet under the filter, how can i fix, new part? pipe dope? idkk
post #5 of 8 Old 02-12-2011, 09:19 AM Thread Starter
xjpalmerie
yes it does look like its one houseing, anyway to get around buying a new one?
post #6 of 8 Old 02-12-2011, 09:30 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Search "oil filter adapter". It's as easy as replacing a set of 3 o-rings you buy from the dealer for about $8.
cruiser54 is offline
post #7 of 8 Old 02-12-2011, 09:37 AM Thread Starter
xjpalmerie
thanks man
post #8 of 8 Old 02-12-2011, 10:10 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Your 89 will have a regular six-sided bolt holding the adapter on. Don't get freaked out when reading about removing the later models' bolts with the T-60 Torx head.
