Oil leaking from top of 4.2 valve cover - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Oil leaking from top of 4.2 valve cover
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 02-21-2005, 08:28 AM   #1
Blue Flames
I am very new to jeeps. I have 2 a 90 with a 4.2 and a 91 with a 2.5. On the top of the 4.2 valve cover there are 3 holes. one is the oil cap. I'm not sure what the other holes are for but they have hoses conected to them and oil is leaking from both of them. what the best way to stop this. Also it looks like there was a hose about 2" in dia. that came from the bottom of the intake filter holder and went to another hole on the side of the engine. This hose is gone and missing. What is it's purpose and should I replace it?
Thanks
Joe
Blue Flames is offline   Reply With Quote
Unread 02-21-2005, 09:10 AM   #2
gosupes
Those other holes in the VC are for the PCV system. Get a Chiltons or other shop manual for routing and other information. The other is for the heat riser off the exhaust manifold to help the engine warm up faster. Not generally needed. The theory is that cold engines put out a lot more emissions due to running rich. The faster the engine warms up, the better.
1986 CJ7, 4.2 w/4.0 head, TFI-HEI hybrid ignition, Clifford manifold w/Holley 390 w/cold air intake, OBA (in work), 150 amp alt., 4.5" lift, Woody CV shaft, 4.10 gears - lunchbox in front, Truetrac in the back, twin-sticked, blower upgrade for running topless, keepin' it simple.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline   Reply With Quote
