oil leak from distributer shaft - JeepForum.com
post #1 of 3 Old 09-10-2001, 01:18 PM Thread Starter
jmsjeep
All of a sudden I am getting a slow leak where the shaft enters the engine. Is their a gasket etc. Can I just try and tighten it or will that mess up timing. It looks like I need to be careful.
I wonder were that dirt road goes?
'89 YJ 4 banger all stock, replacing all the worn out guts first, 97 grand cherokee limited
jmsjeep is offline
post #2 of 3 Old 09-23-2001, 09:07 AM
Trekker88
Yes there is a gasket on the shaft.
Trekker88 is offline
post #3 of 3 Old 10-15-2001, 12:20 PM Thread Starter
jmsjeep
I have replaced the gasket, but it still leaking. any other suggestions.
jmsjeep is offline
NP231 Tail Shaft Leak Fix sentinal02 Fabrication Shop 46 03-09-2014 05:27 PM
AMC 318 or 360 distributer help a88ruby Engines & Drivetrain 0 04-30-2009 01:49 AM
4.0l distributer coreed Engines & Drivetrain 3 01-13-2009 07:41 PM
Front and rear pinion leak drive shaft curtagain Engines & Drivetrain 3 10-20-2008 03:58 PM
fluid leak, sending unit in front of shaft blueknight44 Engines & Drivetrain 0 11-22-2006 03:50 AM
