Oil leak? 05 Tj - JeepForum.com
post #1 of 3 Old 03-18-2013, 06:08 PM Thread Starter
Woodcock1187
Oil leak? 05 Tj
I have notice oil leaking from somewhere on my TJ. There is residue up towards the rear main but also I noticed that it looked like it was coming from the drivers side right by the cats. So I am curios if anyone had experience the same problem and knows the fix.
Thank You
Woodcock1187 is offline
post #2 of 3 Old 03-18-2013, 09:06 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Check your valve cover first. Sometimes the screws work loose and the gasket leaks.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 3 Old 03-19-2013, 01:21 AM
seattle_yj
It probably is the valve cover. Clean it all up nice with purple power and try and pin point the leak locations. Replace the valve cover with a felpro brand blue rubber gasket if it is the culprit.
seattle_yj is offline
