oil coming out of dipstick - Page 2 - JeepForum.com
post #16 of 18 Old 10-03-2013, 01:47 PM
Tyler980
Did you change from carter carb? Or is it just the choke that's changed? If its the carter carb one of the hoses coming from top of valve cover goes to back bottom of carb, it'll be a bigger port. Other goes into air cleaner if you have stock one. If not hook it up to a separate filter
Tyler980 is offline
post #17 of 18 Old 10-03-2013, 02:58 PM
rocketboy
rocketboy's Avatar
So, read post 8. It tells you where to hook it up. What's the deal? It's been three weeks since the last post.
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
rocketboy is offline
post #18 of 18 Old 11-12-2013, 11:12 AM Thread Starter
Shotgun123
1987 YJ Wrangler
Well I found the problem it was the value cover gasket leaking duh it help when a nan look s under the hood ...my son found a screw that wasn't tight....leak is gone..I try. ; )
Shotgun
Shotgun123 is offline
