oil coming out of dipstick - JeepForum.com
post #1 of 18 Old 09-06-2013, 07:36 PM Thread Starter
Shotgun123
1987 YJ Wrangler
What is oil coming out of the dip stick? What are the causes? Could I have a vacuum mis placed from transfer? What can I do?
Shotgun
Shotgun123 is offline
post #2 of 18 Old 09-06-2013, 09:56 PM
uberxj92
1992 XJ Cherokee
Maybe a bad PVC.
What model, engine, miles?
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 18 Old 09-06-2013, 10:10 PM Thread Starter
Shotgun123
1987 YJ Wrangler
Same 4.2l 1987 120k
Shotgun
post #4 of 18 Old 09-06-2013, 10:15 PM Thread Starter
Shotgun123
1987 YJ Wrangler
Only difference is I changed from eletric choke to standard choke carb...witch doesnt have all tge vacuums....I was reading a post from another and I was suggested pcv value. I have ine blocked off and the other just sitting there...do I need to hook vacuums hoses to them if so where do they go?
Shotgun
post #5 of 18 Old 09-07-2013, 07:28 AM
uberxj92
1992 XJ Cherokee
I'm not a Carb person. I would try Haines maybe
uberxj92 is offline
post #6 of 18 Old 09-07-2013, 08:13 AM Thread Starter
Shotgun123
1987 YJ Wrangler
How can I get hold of Haines. Can u buz him?
Shotgun
post #7 of 18 Old 09-07-2013, 10:10 PM
uberxj92
1992 XJ Cherokee
Sorry I meant Haines book for the jeep. Parts stores or even at the library
uberxj92 is offline
post #8 of 18 Old 09-08-2013, 03:10 PM
rocketboy
rocketboy's Avatar
The PCV system needs to be hooked up. If you have both lines blocked off, there's nowhere for the crank case pressure to go. That's why oil is blowing out your dipstick.
The PCV valve in the front of the valve cover needs to be hooked up to vacuum below the carburetor. The vent at the back of the valve cover hooks up to the air cleaner.
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
rocketboy is offline
post #9 of 18 Old 09-08-2013, 04:41 PM
mmerlinn
Unplug your plugged transmission vent if it is your transmission dipstick tube.
mmerlinn is offline
post #10 of 18 Old 09-09-2013, 12:49 PM Thread Starter
Shotgun123
1987 YJ Wrangler
Pcv values, front still get hooked to a standard choke carb, and tear when I get a breather. .zI need to do that as well with standard choke
post #11 of 18 Old 09-09-2013, 12:52 PM Thread Starter
Shotgun123
1987 YJ Wrangler
Don't forget I updatedfrom eletric choke to standard choke ....still hook up as listed above ....ill try that
post #12 of 18 Old 09-09-2013, 09:23 PM
rocketboy
rocketboy's Avatar
Choke type should have nothing to do with the pcv valve. You need to hook that up to release pressure in the crankcase.
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
post #13 of 18 Old 10-03-2013, 01:09 PM Thread Starter
Shotgun123
1987 YJ Wrangler
Where do i connect them, is my problem....the carb change made a difference...
Shotgun
post #14 of 18 Old 10-03-2013, 01:09 PM Thread Starter
Shotgun123
1987 YJ Wrangler
It is blowing bad
Shotgun
post #15 of 18 Old 10-03-2013, 02:04 PM
DaemonForce
I had this problem up until my engine finally nuked itself on the freeway. Bad PCV plumbing, bad oil, cracked head and worn out piston rings. This was at 180K so there's definitely some life left in your engine. Check your PCV plumbing.
DaemonForce is offline
