-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   oil coming out of dipstick (http://www.jeepforum.com/forum/f19/oil-coming-out-dipstick-1572313/)
Shotgun123 09-06-2013 06:36 PM
What is oil coming out of the dip stick? What are the causes? Could I have a vacuum mis placed from transfer? What can I do?
uberxj92 09-06-2013 08:56 PM
Maybe a bad PVC.
What model, engine, miles?
Shotgun123 09-06-2013 09:10 PM
Same 4.2l 1987 120k
Shotgun123 09-06-2013 09:15 PM
Only difference is I changed from eletric choke to standard choke carb...witch doesnt have all tge vacuums....I was reading a post from another and I was suggested pcv value. I have ine blocked off and the other just sitting there...do I need to hook vacuums hoses to them if so where do they go?
uberxj92 09-07-2013 06:28 AM
I'm not a Carb person. I would try Haines maybe
Shotgun123 09-07-2013 07:13 AM
How can I get hold of Haines. Can u buz him?
uberxj92 09-07-2013 09:10 PM
Sorry I meant Haines book for the jeep. Parts stores or even at the library
rocketboy 09-08-2013 02:10 PM
The PCV system needs to be hooked up. If you have both lines blocked off, there's nowhere for the crank case pressure to go. That's why oil is blowing out your dipstick.
The PCV valve in the front of the valve cover needs to be hooked up to vacuum below the carburetor. The vent at the back of the valve cover hooks up to the air cleaner.
mmerlinn 09-08-2013 03:41 PM
Unplug your plugged transmission vent if it is your transmission dipstick tube.
Shotgun123 09-09-2013 11:49 AM
Pcv values, front still get hooked to a standard choke carb, and tear when I get a breather. .zI need to do that as well with standard choke
Shotgun123 09-09-2013 11:52 AM
Don't forget I updatedfrom eletric choke to standard choke ....still hook up as listed above ....ill try that
rocketboy 09-09-2013 08:23 PM
Choke type should have nothing to do with the pcv valve. You need to hook that up to release pressure in the crankcase.
Shotgun123 10-03-2013 12:09 PM
Where do i connect them, is my problem....the carb change made a difference...
It is blowing bad
DaemonForce 10-03-2013 01:04 PM
I had this problem up until my engine finally nuked itself on the freeway. Bad PCV plumbing, bad oil, cracked head and worn out piston rings. This was at 180K so there's definitely some life left in your engine. Check your PCV plumbing.
The time now is 05:25 PM.
