Oil in the air filter? - JeepForum.com
post #1 of 3 Old 02-22-2003, 09:23 AM Thread Starter
kingjrk
kingjrk's Avatar
Hey Guys,
I just got my first YJ and I've been poking around the engine a bit and I found that the PCV filter is saturated in oil and there's even a bit pooling in the bottom of the filter assembly. Im not too familiar with the 258 but is this normal, and if not what could it be?
TIA
James
1987 YJ, old (180,000) I-6 (258), 3.5" Pro comp suspension lift,Aftermarket seats, Hand-Throttle, Dynastar 1"BL, Rhino lined, Tomken Bumper/Carrier-front-rear, Weber carb, Nutter, TFX exhaust.
kingjrk is offline
post #2 of 3 Old 02-22-2003, 12:21 PM
MudLover
MudLover's Avatar
The same thing happnes on my CJ. I don't worry about it that much because it doesn't seem like there's enough there to actualy enter into the crab.
Marc
1979 CJ5 project
"Life is an issue of mind over matter. Ya see, I don't mind, and well...you don't matter."
Red Jeep Club Member #2
MudLover is offline
post #3 of 3 Old 02-22-2003, 02:05 PM
Birdawg
Birdawg's Avatar
Found this site the other day. Lots of do iit yourself stuff there. Not too far down the page is the topic "Air filter solution". It tells you how to fix the problem you describe. Hope this helps.
http://4wheeldrive.about.com/cs/jeep...ance/index.htm
1992 YJ 4.0 Liter HO I6
Sitting on a Rock in the Bay
Air Restrictor & Chicken Bones Gone,20 Gal.Gas Tank :) Audiovox CD Sound Bar, Front Tow Hooks. Hard & Soft
Tops. 31" x 10 1/2" x 15" Coopers
Sumer Projects:2 1/2" Rubicon Express.(Done) New Metalic Paint.(Done)
31" Tires (Done), Bed Liner. Dome Light for Soft Top
Blue Jeep Member #15
Birdawg is offline
What is the best Oil filter h2ojeep Engines & Drivetrain 4 01-08-2009 07:42 AM
Would You Pay $200 For an Oil Filter? CopperCJ7 Engines & Drivetrain 213 07-02-2008 09:19 PM
K&N Filter TJs06TJ Engines & Drivetrain 5 05-11-2007 03:27 PM
Oil in filter lid on 90 6 cyl. Blue Flames Engines & Drivetrain 1 02-25-2005 09:45 AM
K&N oil filter slickwillie Engines & Drivetrain 4 06-11-2004 11:12 PM
