Offenhauser adn Holly Setup - JeepForum.com
post #1 of 1 Old 05-13-2002, 02:35 PM Thread Starter
Infedel
I converted my '84 CJ-7 with a 258 over to running an Offenhauser Intake Manifold and Holly 390CFM carb. With the change, came a reduction in vacume lines. The Holly setup is a bit different than the Carter. The engine seems to run relatively fine (better than it did), however, I'm sure I don't have somethign hooked up right.
1.) At the base of the carb., facing the valve cover, there is a vacume port. What should this be running to? I currently have it blocked off.
2.) On the Offenhauser manifold, I blocked off the center port, however I saw that El Rustico has his hooked to the PCV. My PCV is currently connected to the other vacume port on the carb, facing the firewall.
Any help would be appreciated.
'84 CJ-7
AMC 258 Stroker
Centerforce II Clutch
1" Body Lift
1" Shackle Lift
33x12.5" SSR Tires
Painless Wiring, Stainless Steel Dash
Infedel is offline
Offenhauser Intake Carbs Nspratt14 Engines & Drivetrain 2 11-08-2009 09:45 PM
Offenhauser Intake any good?? jimbos76cj Engines & Drivetrain 0 02-04-2009 11:04 AM
Offenhauser intake 4 or 2 bbl gumby Engines & Drivetrain 4 09-14-2003 03:28 PM
Rusty's Flowmaster exhaust setup or custom exhaust setup? 4x4 XJ General Jeep & Off-Road Equipment 2 01-22-2003 02:45 AM
OFFENHAUSER 258 4 BARREL INTAKE 4 SALE TOMFUSE1 Engines & Drivetrain 0 03-12-2002 07:58 PM
