OBDII 4.0 to 5.9L Swap. Wiring Questions - JeepForum.com
post #1 of 2 Old 10-19-2007, 10:38 AM Thread Starter
gunthagunth
gunthagunth's Avatar
Just wondering what I should be swapping over to make this as smooth as possible. I have the 5.9L parts jeep in my yard. I didnt know if I would have to trace all of the wiring and pull all of the sensors wiring out and wire from scratch or if it is as simple as pulling the ECM and all the wiring coming out of it and laying it out. Also would I need to swap the distribution box from under the hood or would that not matter 4.0 or 5.9L. Thanks for any help.
~Jason
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
post #2 of 2 Old 10-19-2007, 09:48 PM
TXjeepTJ
TXjeepTJ's Avatar
pull the ecm and the whole engine wiring harness including the obd2 connector out the donor and put it in your jeep for the 5.9L, i def. wouldnt try wiring it up from scratch lol
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
Wiring info on Swap H_Swank Engines & Drivetrain 5 12-13-2009 01:26 PM
5.9 swap into a tj wiring up holdenjeeps Engines & Drivetrain 1 11-09-2008 07:05 PM
ZJ 5.2 to TJ swap (wiring harness) will228 Engines & Drivetrain 1 02-09-2008 07:08 AM
Swap wiring elimination? LeeV Engines & Drivetrain 0 01-12-2008 07:35 AM
Amp Wiring Questions HiRoller Audio, CB & Ham Radios, GPS, & Electrical 2 04-13-2006 08:22 PM
