O2 sensors when to clean and when to replace - Page 2 - JeepForum.com
post #16 of 30 Old 09-10-2013, 07:05 AM
V65Ozzie
Originally Posted by Terry777 View Post
Great info,
I was always under the impression the honey comb structure did nothing more than help the air become moist and it was the moisture that was the culprit that helped the emission's readings for the dinks or I mean Government...
Always glad to help clarify things. Converters are the main reason that most exhaust systems are stainless steel now, the h20 would speed the rust in the system from the inside out. Back in the day I worked for meineke, and the way we tested the pipes for strength was to squeeze them with a pair of channel locks, you'd be amazed at how many pipes looked solid, and crumbled when squeezed. The aluminized coating on the steel pipe was still good, but the pipes had rusted from the inside out.
Retreat? Hell, we just got here......
V65Ozzie is offline
post #17 of 30 Old 09-10-2013, 07:08 AM
Speedymcracer01
K thank you...by the way an hour ago i pulled my o2 sensor to see if it looked bad. When i pulled it out it was black and white i took a shop rag and wiped it off real good most of it came off except for some of the white. Is this normal wear for an o2 or is it looking like its about served its purpose and will need to be replaced soon?
Speedymcracer01 is offline
post #18 of 30 Old 09-10-2013, 11:00 AM
V65Ozzie
Like I said, it's hard to tell because the workings are inside, but it's normal to have some soot and stuff on the outside, the white is probably discoloration due to the high heat that the catalytic converter "lights off" at, and that would be quite normal.
V65Ozzie is offline
post #19 of 30 Old 09-10-2013, 07:26 PM Thread Starter
Terry777
1997 XJ Cherokee
What vehicle, what year, what sensor front rear?
Did you spray clean the inner part ? you should...
Terry777 is offline
post #20 of 30 Old 09-10-2013, 10:26 PM
Speedymcracer01
98 GC Laredo the rear sensor and no i didn't use any chemicals i didn't want to spray anything inside of it
post #21 of 30 Old 09-11-2013, 12:47 PM Thread Starter
Terry777
1997 XJ Cherokee
It`s sealed inside should be fine. If not it wouldn`t last in those conditions...
look under Google in search images for O2 sensor...
The ones in the Jeeps from my understanding has a ceramic stem that takes the 1st line of the heat so that's the only part that is exposed, the heat passes through the ceramic and is absorbed from there to the other parts were the voltage is read by means of the temperatures. Sorry I can`t explain if colder temps give higher voltage reading or lower but it`s online if you want to know...
Terry777 is offline
post #22 of 30 Old 09-11-2013, 11:18 PM
Speedymcracer01
Alright thanks for the info. I believe I'll just go ahead and replace it. It has nearly 200k miles on it and it's wires have been wrapped around the drive shaft before. So I'd say it's served it's purpose,and i might as well replace it now before it decides to go out on my way to work pr something
post #23 of 30 Old 09-12-2013, 02:12 PM Thread Starter
Terry777
1997 XJ Cherokee
There is a product called sensor clean, did you reset the ECU after you cleaned the O2 sensor ?
I replaced the cat O2 sensor in my 91 Acura Integra due to it looking worn out and rusted on the outside only to have it make no difference and piss me off wasting $100, just a heads up I did reset the ECU...
I guess from all the warnings it`s about time I get a zap strap around my O2 wires before the get sucked in to the drive shaft.
Cheers
Terry777 is offline
post #24 of 30 Old 09-12-2013, 02:30 PM
V65Ozzie
Oh, if you ever blow a headgasket and coolant gets into the exhaust, you may as well go ahead and replace the converter and the sensors, coolant is deadly to both the converter and the sensors. Just FYI.
V65Ozzie is offline
post #25 of 30 Old 09-13-2013, 12:30 AM
Speedymcracer01
Cheers
When i cleaned off the o2 i also cleaned the plugs and sanded my distributer electrodes inside and out including the ignition coil. When i do anything to sensors or ignition systems i take my battery out before i start. So it should have reset all that
post #26 of 30 Old 09-13-2013, 04:43 AM
5-90
5-90's Avatar
1988 XJ Cherokee
I took out both O2 sensors and cleaned them, the down pipe one has been replaced at some time but the rear one looks like it`s the original from 1997 :]
After cleaning them I noticed while in sitting in traffic it idles a lot smoother sometimes so smooth I thought it stalled...
With that said the rear one has been there for many years and just cleaning the soot off made a noticeable difference, but would a new one give any better temp reading? I`m not techy with electrical and the wires don`t feel crispy or have any signs wear just the outside housing is as old looking as the stock muffler no doubt the original one from 97...
Not sure what that inside prong of the sensor is made of, ceramic ?
Thanks for your time, Cheers
Edit : Forgot to mention I reset the ECU...
The sensing element is either a titania or zirconia porous ceramic, and the unit compares the oxygen content of exhaust gas and ambient air. (I don't recall which is which, but I think it's the zirconia ceramic that generates a voltage signal - being an "air battery" - and the titania that generates a variable resistance - which is used as a "voltage divider" on a reference voltage signal.)
The porous ceramic cannot be cleaned, and it eventually clogs up with carbon.
As far as service life? Spec for OBD-II is 60,000 miles for all sensors - field reports show useful life of 60,000-75,000 miles for the "upstream" sensors and up to 100,000 miles for the "downstream" sensors.
OBD-I is usually spec'd to about 75,000-80,000 miles, I've seen them go out to 110,000-120,000 or so.
Pre-OBD? I don't recall the spec life, but the longest-lasting HEGO I've seen still generating a useful signal had 220,000 miles on it...
(As the control systems get newer, they're pickier about the signals generated.)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #27 of 30 Old 09-14-2013, 10:44 AM Thread Starter
Terry777
1997 XJ Cherokee
So why when I clean just the O2 sensors the noticeable change in idle?
Seems misleading to say you can`t clean them leaving the assumption you must buy new. Don`t just take me word for it try it and see, it works...
Like I said before I already caved in once on my Acura and went with the new due to it looking old and it made didily squat of a change and you can`t return those only exchange... $100 waisted
Terry777 is offline
post #28 of 30 Old 09-16-2013, 06:50 AM
vadslram
Sometimes you can clean them, sometimes you can't. It entirely depends on what the contaminate is. If all you have is a carbon buildup then by all means clean it and you will be happy. If you put some snake oil in the gas tank, you have leaking rings or intake valve stem seals, or your head gasket is leaking coolant into the cylinders then the stuff that builds up on the sensor 1, won't just clean off anyway and 2. will actually change the electrical properties of the sensor causing false readings.
And that is just the exhaust stream part. If the seal where the wire comes out of the sensor is bad and water gets in it won't read right no matter how much cleaner you spray.
vadslram is offline
post #29 of 30 Old 09-16-2013, 12:20 PM
V65Ozzie
Yeah, what he said......
V65Ozzie is offline
post #30 of 30 Old 09-16-2013, 12:26 PM
V65Ozzie
I finally put a stop to O2 returns where I work, employees were just taking them back for whatever reason, and doing a refund, so I basically had a bunch of used O2 sensors that worked just fine, that when I returned to the manufacturer, I lost my money. The "mechanics" in this area tend to guess, and when they guess wrong their customers want the money back, so they would return them as defective. Now we will defect exchange it once, no cash returns. Didn't make a lot of friends with that........
You'd be amazed at how much stuff these so called "mechanics" blame on an O2 sensor....
V65Ozzie is offline
