O2 sensor...maybe - JeepForum.com
post #1 of 3 Old 07-25-2005, 11:26 AM Thread Starter
tcpatter
O2 sensor...maybe
Here's the problem with the TJ. When it starts up (and is cold) it has a hard time holding decent RPMs. It will usually drop really low and if it doesn't stall, it sounds like it wants to really really bad. So far the exhaust manifold, CPS, and VCC (I think) has all been replaced and still no go. Today I'm gonna be checking the O2 sensors and maybe the TPS. Any other suggestions?
tcpatter is offline
post #2 of 3 Old 07-26-2005, 12:22 AM
TXjeepTJ
TXjeepTJ's Avatar
iiii dont think 02 sensor would be causing that problem.. does it constantley have a hard time holding a decent rpm? you might want to check the throttle position sensor it might have water damage to it.. 02 sensor would send such a signla to the computer telling it to do a weird idle lol
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #3 of 3 Old 07-26-2005, 06:27 AM Thread Starter
tcpatter
Well I disconnected the O2 sensor and it didn't help. So I'm wondering about the TPS. It does almost always have a hard time holding the RPMs, but mainly when it is still cold
tcpatter is offline
TP Sensor wyntyrose Engines & Drivetrain 2 02-06-2009 09:02 AM
4.0 O2 sensor bad again flashsuperstar Engines & Drivetrain 0 10-24-2008 05:18 PM
TPS Sensor going out. (03 4.0) Si1ver03Rubicon Engines & Drivetrain 0 03-27-2008 11:15 PM
MAP Sensor JeepMKcomin Engines & Drivetrain 0 12-05-2006 02:57 PM
m.a.p sensor crackernutz Engines & Drivetrain 1 04-29-2005 11:37 AM
