o2 sensor bypass - JeepForum.com
post #1 of 3 Old 05-21-2008, 07:19 PM Thread Starter
badoosh27
badoosh27's Avatar
o2 sensor bypass
i am looking to make or setup a bypass for my o2 sensor, but dont know how. i think i need to set up some sort of resistor, but what resistance do i need? any info or help is appreciated. thanks
2001 Tj with 4.0 btw
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
badoosh27 is offline
post #2 of 3 Old 05-22-2008, 04:58 PM
Krom
You have to have the front sensor, its what the ecu uses to adjust the fuel mixture. You can remove the cat, and rear sensor, replace the rear sensor with a oxygen sensor simulator, do a search they are available all over the place
http://www.afterthoughtsauto.com/o2sim.html
http://www.mkiv.com/techarticles/oxy...sor_simulator/
http://rpmoutlet.com/gmo2s.htm
Krom is offline
post #3 of 3 Old 05-22-2008, 07:46 PM Thread Starter
badoosh27
badoosh27's Avatar
yeah, thats what i meant i needed. i have 2 down pipes, each with 3 cylinders and its own "precat" and o2 sensor, then they join together and theres one more sensor, then my main cat. so do i need two simulators? or do i just put it on the back one?
i am adding more o2 to the intake which makes the computer think its running really lean, so i need some way to trick the ECU into thinking it has the perfect amount of o2 coming out. will a simulator do that?
Nutter Bypass on a 79 258? Calebster Engines & Drivetrain 2 11-06-2008 07:38 AM
How do you bypass gps? manley5321 Audio, CB & Ham Radios, GPS, & Electrical 9 05-06-2007 07:06 AM
Bypass oil filters ukjeeping Engines & Drivetrain 4 02-25-2005 10:17 AM
Air Bypass Valve OlllllllO Jeep1 General Jeep & Off-Road Equipment 0 01-07-2005 05:38 PM
nutter bypass DIESEL Engines & Drivetrain 1 04-17-2004 04:34 PM
