Nv247 Transfer case. HELP PLEASE!!! - JeepForum.com
post #1 of 1 Old 05-01-2012, 12:14 PM Thread Starter
WSU_Raider
Ok I haves 99 jeep grand Cherokee limited. Original transfer cases chain went through the case. I purchased a used nv247 to swap out with the bad one. I just pulled old case out which was an absolute pain. I'm working on I stalling the new case, but i can't get it on the transmission shaft. their is, what appears to be a black plastic spacer? In inside the bell housing of the case behind the input bearing that goes on tho the splines of the shaft. The spacer is free floating inside of their and every time I go to push case on shaft I can't, it's holding me up. None of the manuals or schematics show or say about this? What do I need to do?? I'm am lost because no transfer case iv swapped has had this issue
WSU_Raider is offline
