#1 | |
NP231 Tcase splits
My son's 91 XJ split it's transfer case while driving down the highway. It was not in 4WD. Has anyone ever seen a NP231 split in half? This XJ has a 6 inch lift and 35s. We have done a slip yoke eliminator kit on the output shaft of the tcase and replace that drive shaft. But we have never changed the front drive shaft. We also have a Tereflex long arm kit up front that has been adjusted to move the front axle back where it should be after moving from 4 inches of lift to 6 inches. My quess is we ran out of extension on the front drive shaft and that caused the tcase to split. Any ideas or suggestions are appreciated.
#2 |
Or the CV joint in the front driveshaft seized up and when that happended it caused bad things to happen.
#3 | |
http://www.jeepforum.com/forum/f9/broken-t-case-pics-979282/ http://www.jeepforum.com/forum/f9/transfer-case-broke-353516/
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#4 |
Thanks for the replies. After thinking about the extra lift and resetting the front axle with the adjustable long arm kit, I bet I am out of extension on the driveshaft and that worn out the CV joint. I am going to have my son pull the front driveshaft tomorrow and we will find out.
#5 | |
Friends don't let Friends run Bosch My Wifes Cake Site - Check the Jeep Under Carved & 3D Last edited by Pillswoj; 03-13-2010 at 10:13 AM.. |
#6 |
I would have to agree with that assessment. After doing everything we have done I am embarrassed that we did not replace the front shaft. You drop the bucks for a long arm kit, new shocks/springs, SYE, new rear shaft, 35" tires, skid plates, bumpers, etc and yet we did ignore that front shaft. Well at least a got a good replacement NP231 for $125 and put the SYE into it. So other than the time and energy, not too much wasted. At least my kid and I got to spend time together working on Jeeps!
#7 |
JEEP FREAK
Did you guys rebuild the front driveshaft too?
98 TJ |
#8 |
Nope. It is the original.
#9 |
Just got the old front driveshaft off and the centering ball is totally trashed. Time for a new shaft.
Thanks everyone for your input. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
