NP231 fluid capacity - JeepForum.com
post #1 of 2 Old 12-07-2009, 10:34 AM Thread Starter
Krawl
So here's a question for the guru's. What is the fluid capacity of the NP231, I looked here and found 1.1 quart, but other sites say 2 quarts. What is the correct answer? I got 2 quarts in mine before it came out the hole.
I like it with the grass cut low, big mountain tops, the valley below
Krawl is offline
post #2 of 2 Old 12-07-2009, 01:55 PM
NonRubicon
Haynes manual says 3 pints (1.5 qts) for the NP231. Last time I changed my NP231 fluid it took about this much, maybe a little more. It may depend on how much you get to drain out. 1-2 quarts seems to be the range.
In any case, the correct level is up to the fill hole. Make sure you are on level ground or you may get a false fluid level.
NonRubicon is offline
8.8 fluid capacity and SOLID diff cover chadsmeltzer General Jeep & Off-Road Equipment 32 03-30-2015 11:30 AM
High Capacity Oil Filter for the 4.2L 258 Lasher242 Engines & Drivetrain 6 01-23-2010 01:14 PM
D44 fluid capacity with Riddler diff covers & ARB's? TJlady Engines & Drivetrain 5 03-26-2009 12:10 AM
Air Tank capacity Libtekguy General Jeep & Off-Road Equipment 27 12-09-2007 05:31 PM
Towing Capacity for '88 XJ jvaughn Street Jeep Forum 2 09-13-2007 11:29 AM
