NP231 23 spline to 21 spline - JeepForum.com
post #1 of 4 Old 03-01-2007, 09:10 PM Thread Starter
ROG97
ROG97's Avatar
Can the input shaft on the NP231 be easily changed from 23 spline to 21 spline.
The reason I ask is I found a good deal on a 231 with a tera low installed but it has the 23 spline input, I have the AX5 transmission in a 97 4 banger.
Thanks
If you're not living on the edge you're taking up too much space
ROG97 is offline
post #2 of 4 Old 03-26-2007, 02:07 PM
jeepdrvr101
Yes
Mike
89 YJ Islander, White with blue pearl custom paint, 4.2 Nuttered, Holley carb, Light bar W/4 Kc daylighters, 32x11.50r15, Unknown lift, kenwood sound, Rockford fosgate Amp x2, Kicker Amp(1)
A work in progress...
2006 Ram 1500 TRX4 5.7 HEMI All stock
jeepdrvr101 is offline
post #3 of 4 Old 03-26-2007, 05:13 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
you're looking at a complete disassembly of both cases to swap it out. or just one if you want to spend the $$ and buy a new input gear. but yeah, it can be done.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #4 of 4 Old 03-26-2007, 10:40 PM
laredo_man
I'm not 100 % on this .
but if the old t-case is the 2.72
and you want to go to 4:1 .the input shaft off the old case won't line up to the planetarys of the 4:1
laredo_man is offline
dana 30.....30 spline? webdr Engines & Drivetrain 10 10-14-2013 07:42 AM
Where can I find a 23 spline input shaft?(NP231) crf450ish Engines & Drivetrain 12 10-08-2013 07:52 PM
D30: 27 spline or 30 spline??? klimb2xs Engines & Drivetrain 4 08-04-2009 12:03 PM
21 Spline NP231 to 23 Spline Rodeo1488 Engines & Drivetrain 6 04-15-2006 08:16 AM
27 to 29 Spline XJ96PA2 General Jeep & Off-Road Equipment 4 08-08-2005 12:22 PM
