not a jeep but i got a drivetrain/brake problem on my truck - JeepForum.com
post #1 of 2 Old 05-18-2012, 04:47 PM Thread Starter
southernjeep80
heres a link i posted on the truck forum. basicly i got an intermitant shutter from the rear. i jacked truck up and the driver side tire turnes fairly decent and freely but the passenger side tire is locked up unless i put it into drive.
http://www.fullsizechevy.com/forum/g...hake-rear.html
southernjeep80 is offline
post #2 of 2 Old 05-19-2012, 02:24 AM
jnicewan
I dont know if the guys over there are serious or not about the use of an additive but the G80 does not need it, but it will not hurt it at all. The additive is simply a friction modifier and many fluids come with it already in the fluid and those fluids are compatible.
It sounds like you might need to pull the drum off of that one side, probably both to compare what you see. Seems like you might have something broken in the brake assy, maybe a shoe return spring. On a dual servo brake, without the return spring working if a shoe hangs on the drum it will make it grab and more than likely let go over and over again, kind of like you are experiencing. If someone is doing the work for you then have them check it out ASAP.
jnicewan is offline
Jeep J20 Engine & Drivetrain freebird Engines & Drivetrain 1 09-06-2010 11:39 AM
QUICK - 97 TJ Drivetrain Problem ??? JAX Engines & Drivetrain 2 09-12-2009 12:13 PM
anybody know anything about isuzu motors and drivetrain in a jeep? :) psycopanther Engines & Drivetrain 2 04-19-2009 07:58 PM
Drivetrain Problem SpookyJohn Engines & Drivetrain 1 04-07-2008 05:56 PM
2001 tj drivetrain problem xtremebikr04 Engines & Drivetrain 0 10-10-2006 05:39 PM
