noisy lifters after timing chain replacement - JeepForum.com
post #1 of 2 Old 03-07-2009, 07:37 AM Thread Starter
jeffarcher401
1979 J-Series Truck
Was plowing snow in low range of course (basically just off idle) and the engine just quit. Wouldn't start but just knew it was the timing chain. 360 has an edelbrock performer kit (chain, cam, intake and 4bbl carb) with about 100K on it. Ran really strong with no oil consumption (could pull the mountains around here in 3rd (400 turbo quadra trac) with no problem). Ok replaced the timing cover due to scored oil pump gears, fuel pump eccentric, fuel pump, another edelbrock timing set and new oil pump gears. Tolerances came in to spec on oil pump. Before had about 40lbs. oil pressure at start up then drops to 20 and even less at idle monitoring crappy factory gauge. After is the same senerio but hung a gauge on at pump and actually reads around 20 at idle which I can live with. The problem is the valve train is for better words clattery which it wasn't before the timing chain went. Been driving it so lifters could pump up but no change. Really noisy at start up then quiets down some after warm up. Engine runs strong as before, even better. Didn't pull any valve covers yet (waiting for the weather to break) so don't know if rocker arms are loose or if the upper end is actually getting any oil. Any suggestions before I tear into it would be appreciated. Thanks.
jeffarcher401 is offline
post #2 of 2 Old 03-13-2009, 09:13 AM
440_Magnum
Check for bent pushrods... I don't know if the AMC 360 has enough clearance for the valves to completely miss the pistons or not when the chain breaks (I do know, for example, that the Mopar 318 does not, so it doesn't have to be a "high performance" engine to bend valvetrain parts :-/) Since the engine runs strong I'm guessing that even if you did kiss a few valves it didn't bend the valves themselves, but it could have tweaked the pushrods which now causes a little too much clearance in the valve train.
440_Magnum is offline
timing chain replacement? what mileage? evilpsych Engines & Drivetrain 17 03-18-2015 09:21 AM
timing chain noise?? cherojeep Engines & Drivetrain 13 03-11-2014 07:02 AM
CAM upgrade for 2000 4.0 - camshaft, lifters, timing gear? Big-n-Broke-YJ Engines & Drivetrain 2 11-07-2007 06:45 AM
Loose timing chain? jadams68 Engines & Drivetrain 5 07-03-2003 06:02 AM
Timing chain replacement CJ8DV8 Engines & Drivetrain 2 07-30-2002 10:45 AM
